Mrmonk7663
I posted briefly about my 3203 I am building. Here is my project log.
I picked this thing up for $150 and an old air compressor. It was very rough. I started by cutting the floor out and sanding/stripping it. I added steel diamond plate for the new floor. I rust treated and primered the kart, then painted it.
From here, I redid the suspension. New spindles, tie rods and A-arms were added along with some heavy duty shocks from GPS. Stainless hardware was used for most bolts and nuts. I liberated a predator non hemi from a water discharge pump. I acquired (new). The predators are red on the water pumps. I added a custom to my spec stainless steel 1” header to clear the frame with suspension compresses. Topped that off with a RLV muffler. For the carb I used a Japanese superjet with modified circuitry and bigger low and main jetting, along with a modified emulsion tube. Intake is an Arc billet piece with the nuts “sunk” in the adapter to increase flow. Typical clone filter with sleeve.
Tires for the front are 15x6x6 knobby from Argos. Rear wheels are 8x8.5 from BMI with 20x10 kinda scorpion. Rear wheels are 4x4 and I used a hub from BMI.
Gearing is 60x9 with a #40 chain. Finished it off with a GPS 6” torque converter.
Axle is 40” from BMI
Kart starts on first pull and sounds amazing. Throttle and brake still need to be hooked up, and the tie rods need to be attached to the a-arms. I plan on doing that tomorrow. Also a couple more pieces of foam need to be fitted along with the seat reinstalled. Other than that she is ready to rip. It’s been a fun project. From the way the torque converter engages in the jackstands...I can tell this thing is. Going to rip!!! Next up is finishing the Baja and starting the build on the 30032 yerfdog. The Baja has a thread; I’ll make one for the 30032 soon.
Enjoy the pictures!!!
Side note-I’m going to be testing out some steering bushings that can be installed without removing the steering shaft in order to take up the slop these Yerfdog have. I’ll report back with results and information of successful.
