31cc ryobe engine
Russ2251
AZUSA:Powered by LAWN-BOY
Broken rings can sometimes occur if ring gap aligns with exhaust port. End of ring can snag and snap. This is why some 2 cycle manufactures will pin rings to prevent them from turning in cylinder bore. Would be a good idea to put a small champher on ring end gap for rings that are not pinned.
oscaryu1
Well I like to put every engine to use, so usually I try to make them as good as possible. But hey, to each his own.
ed1380
Banned
ATL, GA
sanding the top of the piston is totally ok
i usually take the wire brush on the bench grinder to it
jr dragster T
Cold place
I dont see whats wrong with sanding it as long as you dont mess up the edge of the piston. Im with ed. But I wouldnt use a wire brush in bench grinder though.
Russ2251
I can just imagine the look on my face when a mechanic tells me he sanded my pistons.
Sorry guys, but this is just plain dumb.
Where does it say that it's ok to sand any piston?
Let the flaming begin!!!
jr dragster T
Cold place
I know I would hate it if somone said that to me but he's already done it. I wouldnt do it to my engines I just use alcohol or somthing else to clean my pistons.
oscaryu1
You sound quite young :) Good! Always good startin off early.
Anyhow, a dremel and wire brush could've done quite some good.
