So I'm going to use a built Hemi Predator 212 with a 30 series TC.
The engine is going to put out (hopefully) double the 8HP the 30 series is rated for. The DriveR unit is going to engage at around 4k RPM.
So I've been wondering if the Backplate with the 5/8" Jackshaft and its "one sided" bearing design will handle the engine's output. Seems the high RPM engagement is going to be rough on it.
I've been contemplating one of those engine mounts with built in Jackshafts. I want to use a 3/4" shaft but because this is going on a minibike, I don't think a set up like this http://www.bmikarts.com/Motor-Mount...5p5bKKGpKt5MXKvrz-LJe-AMEmAS3RIYaAnABEALw_wcB will work. Would need to raise the engine up a whole lot.
Thinking about one like this...
http://www.bmikarts.com/Clutch-Mount-without-Jackshaft_p_5380.html
and replacing the 5/8" bearings with 3/4" bearings. Seems as though most 5/8" bearings are 1 3/8" OD. BMI sells high speed 3/4" x 1 3/8" OD Bearings...
http://www.bmikarts.com/Flanged-High-Speed-Wheel-Bearing-34-x-1-38_p_2369.html
I'm not even sure they are 1 3/8" OD, but it would make sense.
I will still need to raise the engine up (along with the jackshaft), but think the 3/4" shaft and having the bearings spaced further apart will be beneficial.
Not positive the bearings will fit. How hard is it to remove/install those bearings?
So what do you guys think? Try the backplate that comes with the TC kit? Or buy the other plate with bearings, replace the bearings, and use a 3/4" shaft with 3/4" bore Driven Pulley?
