30 Series TC Jackshaft Options
So I'm going to use a built Hemi Predator 212 with a 30 series TC.
The engine is going to put out (hopefully) double the 8HP the 30 series is rated for. The DriveR unit is going to engage at around 4k RPM.
So I've been wondering if the Backplate with the 5/8" Jackshaft and its "one sided" bearing design will handle the engine's output. Seems the high RPM engagement is going to be rough on it.
I've been contemplating one of those engine mounts with built in Jackshafts. I want to use a 3/4" shaft but because this is going on a minibike, I don't think a set up like this http://www.bmikarts.com/Motor-Mount...5p5bKKGpKt5MXKvrz-LJe-AMEmAS3RIYaAnABEALw_wcB will work. Would need to raise the engine up a whole lot.
Thinking about one like this...
http://www.bmikarts.com/Clutch-Mount-without-Jackshaft_p_5380.html
and replacing the 5/8" bearings with 3/4" bearings. Seems as though most 5/8" bearings are 1 3/8" OD. BMI sells high speed 3/4" x 1 3/8" OD Bearings...
http://www.bmikarts.com/Flanged-High-Speed-Wheel-Bearing-34-x-1-38_p_2369.html
I'm not even sure they are 1 3/8" OD, but it would make sense.
I will still need to raise the engine up (along with the jackshaft), but think the 3/4" shaft and having the bearings spaced further apart will be beneficial.
Not positive the bearings will fit. How hard is it to remove/install those bearings?
So what do you guys think? Try the backplate that comes with the TC kit? Or buy the other plate with bearings, replace the bearings, and use a 3/4" shaft with 3/4" bore Driven Pulley?
Noseoil
Terrible Tim
Tucson
Yep, give the TAV a shot to see how it works. Keep an eye on things when you launch. It might wear out fast or snap something, but a jackshaft setup will not break if it's set up to run properly. I'm not sure how much power the aluminum plate & bearings can stand up to. I think you're right about 4000 rpm launches & 16 hp, it's going to be a lot harder on parts & chains in general.
A 3/4" jackshaft would be stronger, but will take a little more thought to set up & run. It's a lot stronger if the frame is made with steel, the bearings are farther apart & it's aligned properly on the bike. Let us know what you find as I'm going to be in the same boat sooner or later.
I'll try the backplate first. The kit is so cheap. I'll use the 6" pulley and 10T sprocket that comes with the kit. Don't think I'll get the 60mph I want with the 10T, but I'll be able to see to what RPM I can rev to. If I don't hit 7-7.5k RPM with the 10T, then no need to try the 11T. Maybe I top out at 4k and find out that I, in fact, DID have the only magical TC that spins 7k with 6" pulley. Maybe I WILL have to try a 7" pulley????
I'll make sure to document my findings. I'm going to start a build thread for the minibike soon. Still need to pick a color to paint the frame, a seat, a gas tank. Maybe I'll do a separate thread as well, detailing performance stuff as I play with gear ratios... Max RPM, Max MPH, 0-30 mph time, 60', 330', 1/8 mi, 1000', 1/4 mi times.
Bout to order the Unobtainium Block to raise the engine for the TC and the rest of the TC stuff. Might as well start MiniBike Build Thread. Should finally order the "El Lobo" in 8-10 days - depending on how work goes.
Randy H
Bob I tried those BMI bearings. They are loose on the shaft, from BMI also. It works ok, but there is visible movement of the shaft. Shaft measures .750" bearing ID .755"
It looks you're going with the backplate, but thought I'd give you a heads up if you go a different route.
Good luck, just remember we're all counting on you.
