r97
Measure twice cut once
what i'm saying is the adapter sleeve is 1/8 thick with a 1/4 key. the tc has a built in key that is 1/4 and 1/8 deep that means the tc key will be flush with the inside of the sleeve, you following this? okay so you could slide the tc and sleeve over the 3/4 shaft but the shaft would just spin and the tc would stay stationary, so that wont work, what your gonna need to do is either grind down the tc key and then grind down the 1/4 half of the stepped key then put it on the shaft, or you could grind down a standard 3/16 key and weld it to the tc key, you understand? like i said earlier you may also have problems with the length of the shaft and with the tapped bore in the shaft.
