I would grab it. Parts are easy to come by. (Here at least.) Possible situations for low compression are; no piston or rings, worn rings, hole in the piston or in the block, blown head gasket or malfunctioning compression release. (If it has one.)
All of those are pretty easy to fix, except for a hole in the block.
If possible try get the carb and electrics with it, will make setting it up easier in the long run.
Welcome and good luck.
Jeremy.
