2017 - El Turbo OD/OV
Workin' on gettin' everything wired up
solenoid panel is done
Turbo switch is done (I broke a small piece out of the back plate while drilling the last mounting hole)
it should still be OK
Installed it on the handle bar, right next to the thumb throttle
So you can go from normal drive to Turbo with out much extra effort
Soldered in (3) fuse holders to protect the circuits
Batteries are all hooked up
That looks like everything
Time for a system check
https://www.youtube.com/watch?v=RW1DhH3DfVU
All systems seemed to operate as designed :thumbsup:
The solenoids kick on & off properly, so the 12V circuit checks out
The thumb throttle operates the speed controller normally, so the 24V circuit checks out
& the Turbo kicked in big time, so
Yup, that works too! :2guns:
Well, time for some real world testing
https://www.youtube.com/watch?v=wcMomYC80UE&t=259s
Well,
12V system functions
24V system functions (except for the solenoids actin' up, kinda expected)
36V system (let's just say, it's a work in progress)
When it kicked in, it kicked in hard (as expected) :2guns:
but, the 30 amp fuse couldn't handle it
it blew very HARD (totally blackened)
I guess we'll try a 40 amp fuse
if that don't do it, we'll have to look for something BIGGER
I noticed on the package "up to 32Vdc"
...maybe that's the problem
I guess were moving out of the realm of where (some) automotive stuff is usable (or it at least needs to be factored into the equation)
Bbqjoe
Banned
Location, Location
And I went down to the demonstration
To get my fair share of abuse
Singing, "We're going to vent our frustration
If we don't, we're going to blow a 50-amp fuse"
Went to do another test run
...to see if, moving up to, a 40 amp fuse can handle our 36V jolt of power
but, them intermittent duty solenoids, I used, are NOT cooperating
we need constant duty solenoids for the 24V circuit
...because it's used almost the whole time the karts running.
The (2) for our 36V Turbo should last a while
...because were only using them intermittently like they were designed for.
https://www.youtube.com/watch?v=mdNWqYzCs3U&t=8s
So, I ordered (2) constant duty solenoids
should be here in a few days
Test is on hold til then :ack2:
While waitin' on the constant duty solenoids I ordered,
I think we need to re-work the solenoid circuit.
The way things are set up now,
...the positive (+) of ALL (4) solenoids are wired together & go straight to the 12V battery positive (+)
...the (2) 24V solenoid's negatives (-) are wired together then go to a switch on the dash board, (so I can turn them off) then go to the 24V micro switch, then to the negative (-) of the battery.
Because of the way the Turbo switch is set up, the solenoids would be powered "on" constantly & only shut off when turbo was engaged
but, (for overheating purposes) we really, don't want them on constantly, only when needed. (so I added a switch)
...& the (2) 36V solenoid's negatives (-) are wired together then go to the 36V micro switch, then straight to the battery positive (+) (NOT switched)
I didn't think they needed to be switched because their only used occasionally
but, as we found, if it's not switched & YOU BUMP IT-YOU WILL BLOW THE FUSE-EVERYTIME)
So, I think I got a (revised) plan :thumbsup:
This time,
...the (4) positive's (+) are still wired together but, then go to the switch on the dash, then go to the 12V battery positive (+)
...the (2) 24V solenoids negatives (-) are wired together then go to the 24V micro switch, then go to the negative of the battery.
...& the (2) 36V solenoids negatives (-) are wired together then go to the 36V micro switch, then go to the negative of the battery.
So now, the main switch controls the positive circuit & the Turbo switch controls the negative circuit of the solenoids.
Kansaskart
Pretty cool. Reminds me to order an electronics course so I can make even more of my whacked out ideas a reality.
Got the solenoid circuit switches around :thumbsup:
First, made sure the positive (+) wires would reach up to the on/off switch
...clipped them @ the top of the loop
...slid on some heat shrink & crimped on some spade terminals
For the negative (-) side that used to go to the switch
...just had to clip off the spade terminals
...& slide on some heat shrink
...& solder them together
Boom! like it never even happened
Now, the positive's (+) for ALL solenoids shut off with the on/off switch
...& the negative's (-) are still wired thru the Turbo switch, like before
Workin' on another project to use on this project
Seems like I'm always workin in on a project within a project
So, I rounded up some stuff
... a really old smoke detector
...a broken aquarium air pump
...a circuit tester (blown bulb)
...& some wire
Opened up the smoke detector & removed the hook-up w/wires for the 9V battery
...opened up the air pump, just needed the top half of the case
...unscrewed the wire lead from the circuit tester
Drilled a 5/8" hole in one end of the aquarium case
had to "waller" it out a bit (move drill around while drilling)
...needed a little bigger than 5/8"
...while it was still warm (& kinda soft), I threaded the end of the circuit tester lead into the hole
Then, drilled a 3/16" hole in the same end for the other wire leads
Now, we need a front panel
So, I layed out, marked & cut a panel
out of a piece of left over plastic
from the old TV back
I got the Zero turn kart's arm rests from
A little roundin'-n-shapin' & 4 mountin' holes
Yup!, that should do it :2guns:
Now, we gotta cut out a spot for the meter
...& since this is (self-contained) battery operated (not switched on/off with the kart)
...we gotta add a switch (so, we can turn it off when not in use)
so, gotta cut out a hole for a switch too
* I've typed the word switch more times in the last two weeks than I have in the last two years
"Hey, where did he get the meter?"
I'm glad you asked.
This is the 0-300V 500 amp voltage power meter, that I bought last year for El Dingo. (but, never hooked up) http://www.ebay.com/itm/351031481619
It didn't come with instillation instructions or directions (Chinese stuff never does)
...& I didn't have time last year to look into it much
...so, I mounted it on El Dingo just for looks
Well, when I disassembled El Dingo last week,
I noticed it & said Hmmmm
So, I did some research
I started @ eBay where I bought the meter from last year
I didn't remember where I got it
so, I just looked up a amp/volt meter
Most of the ones that came up first were smaller 100 amp ones
I figured they were the same so, I studied the wiring diagram
Then, just to be sure I looked up a 500 amp meter
I got the bigger meter because El Dingo was supposed to draw over 100 amps
Nope, BAD IDEA they seem to be hooked up totally different :ack2:
so, gotta get that other one outta your head-n-concentrate on the right one
I looked a bit to see if I could find any videos on other people using this meter
But, when you look up meter you get ALL kinds of irrelevant stuff
When you look up amp/volt meter you get better, more relevant info
but, not really what you need. ( mostly definitions & product reviews)
So,
...I think, the thing that came with it is called a shunt, lets look that up
Then, I started gettin' more usable info on how it's actually hooked up
OK, I think we got this :thumbsup:
So, goin' off their diagram, I drew up a diagram I could understand
The meter has (5) wires
(2) in (1) plug & (3) in the other
...the (2) wire plug is to power the meter (it can handle from 5V to 30V)
* so, if your workin' on like 12V automotive stuff, you could just run the meter off the load your measuring
but, for our situation (measurin' 36V & 48V) we gotta supply the meter with separate power
So, to mount this meter on El Turbo:
...First, the meter is to be on the dash as to be seen by the driver
...the shunt is to be mounted to the negative (-) terminal of the battery
...& has the cable going to the motor (load) attached to the other side
...so, the wires going from the meter to the shunt are ~3'
...the negative (-) black wire from the meter "power plug"
...& the black wire from the, Ima call it the "info plug"
...goes to the battery side of the shunt
...the yellow wire from the "info plug" goes to the motor side of the shunt
... to supply power, I will attach an alligator clip to the red positive (+) wire coming from the "power plug" so it can be attached to the 12V circuit of the battery
...to provide "info" from the motor (load)
...I will attach another alligator clip to the red wire coming from the "info plug"
...so I can attach it to the positive (+) terminal motor of the motor
But, then I was thinkin'
Lets see if I can make it simpler to use
...& usable on different karts
...kinda like a multi-meter
That's why, I drew one up where the meter was mounted in a small box & it's powered by an "on board" 9V battery
This way, I could hang the meter up front in the dash area
...& simply
...run the (2) wires from the meter to the shunt, mounted on the battery negative (-)
...& attach the red "signal from the load" wire to the motor positive (+)
Now, (if it works) I can gather data on:
...what the motor on El Turbo is drawing in 24V mode & 36V Turbo mode
...what the brushless motor on El Dingo II is drawing
...& when I get the BIG motor on El Moto, we'll know what that is actually drawing too :2guns:
Got 'er done :thumbsup:
velcro'ed the battery in place (so it ain't floppin' around in there)
All ready to roll :wai:
I'ma try it out tomorrow, if me solenoids show up :2guns:
Constant Duty solenoids finally showed up :wai:
Let's get'em mounted up
First, gotta remove old ones
Didn't want to remove them in advance
(by doin' it all at once, the whole thing was fresh in my mind)
...gotta change some terminals
...old solenoids had 1/4" main terminals & spade terminals
...new ones have 5/16" main terminals & 3/16" ring terminals
Ok, ALL "switched" around (ha,ha I typed switch again) :roflol:
Kool, lets test 'er out, on the stand
if everything "functions within specified parameters"
...we'll road test 'er
...& try out Turbo with a 40 amp fuse :2guns:
https://www.youtube.com/watch?v=Gg0RXG6PV18
First test drive
...using constant duty solenoids for the 24V circuit was a success
...but, the 40 amp fuse for Turbo didn't hold up
I think we are makin' progress because
...so far, each fuse has lasted a bit longer
...the first fuse, I think was a 20A worked during bench testing & stand testing (no load) but popped immediately when I engaged Turbo
...the second fuse a 30A seemed to last like a millisecond longer (I could feel a little surge)
...this time with the 40A fuse, I felt just a bit more of a surge :thumbsup:
https://www.youtube.com/watch?v=VcAt8h8CpTA
Well, (if the meter is accurate)
this motor is drawing more than the label states
Label says:
YT80Y450
Voltage: 24VDC Rated Speed: 2,500 RPM
Rated Current: 25A Output: 450W
The meter showed that it was drawing ~30A consistently @ full speed
I think it even hit 32A a couple of times
Well, nuthin' is gettin' hot yet
So, I'm thinkin', lets keep goin till somethin' pops
(then we'll know the limit or at least have more data to work with)
Again, doin some research, I went back to my old posts for El Dingo from last year
IIRC there was a link to info on this stuff that might help
Yup, I found it :thumbsup:
http://www.alltraxinc.com/files/Doc120-046-A_TN010-Contactor-Fuse-Diode-Lessons-Learned.pdf
...on page 8 of 9, there is info on wires for an EV & a chart of minimum wire sizes for different sized amp controllers
...it starts at 300A requirements & goes up but, the requirement for a 300A controller is listed as, minimum wire standard duty - 4 AWG
...& we shouldn't be anywhere near that
So, Ima make a dual fuse holder (I'll figure it out)
Simply, wire it into my existing set up & see what happens :2guns:
