speedbug78
Building a wheelbarrow based kart, but building it kinda like something from the 50's. Not everything will be period correct, but hopefully it will have the right vibe.
Disclaimer: I dont have internet at home so Im updating this from my phone.
Step 1. Get permission from the wife!
Step 2 - purchase perfectly good parts to cut up.
I just picked up the frame on craigslist for $30. Time to remove pieces that arent going to work. Break out the plasma cutter and grinder.
Step 3. Take a picture of random stuff in the shop.
---------- Post added at 09:08 PM ---------- Previous post was at 08:55 PM ----------
The wheelbarrow was given me by another guy at work. It had too big of rust holes in the bottom to haul sand or mix concrete.
The engine is a 50's vintage REO off of a reel mower that was given me when I was in elementry school and building karts. Im 39 now
At about 2hp and running in reverse rotation it should be interesting at least. The output shaft comes off the cam in correct rotation but 1/2 speed.
The truck wheel is just a size reference.
The front tires are old ones I replaced from our little snapper riding mower. They are shot and a tad small but good for the pic.
My wife didn't want her mug on the site ��
---------- Post added at 09:17 PM ---------- Previous post was at 09:08 PM ----------
I hauled the project over to my dads place and we had a great day hanging out and mocking up pieces for the bucket.
The rear tires need to be a bit bigger and the engine higher.
Hey Dad fits, its even comfy!
Figure out a dash that clears the torque converter and grill placement.
Not bad for a days playing in the shop. I had the ribbed scoop laying around my shop so we plopped it on top.
---------- Post added at 09:27 PM ---------- Previous post was at 09:17 PM ----------
I trucked the bucket back home and started making pieces based on the mockup. Before proceeding I needed my boys approval!
Then I chopped the extra frame off the back
Using some 3/4 aluminized EMT I cut and bent some engine supports.
---------- Post added at 09:50 PM ---------- Previous post was at 09:27 PM ----------
Roughly estimate drive gear ratios:
Engine RPM – 4000 RPM (http://www.reolawnmower.com/data.html)
Output shaft RPM (4000/2) = 2000
Typical 6.5hp cart numbers with torque converter 40mph absolute top speed.
Tire diameter – 20 inches
Tire circumference (pi*diameter) = 3.14*20 = 62.8 inches circumference
Tire circumference in feet (inches / 12) = 5.23 feet
Tire rotations per mile (5280 feet in a mile), (5280/5.23) = 1009
Target top speed. Here I figure I’ve got less than ½ the HP of the 6.5HP carts, I should target something less than ½ the top speed, say 15mph
Tire rotations for 15 miles (1009 * 15) = 15135
If the tire needs to turn 15135 times in an hour at top speed, lets find out how many times it needs to rotate in a minute (60 minutes in an hour) (15135/60) = 252 tire rpm
Now a torque converter says its final drive after it is “fully shifted” is 1:1, so we can directly compare max output rpm to max tire rpm and estimate a drive ratio needed. (2000 output rpm/252 tire rpm) = 7.9:1
After looking around at available parts 7:1 seems doable and I’ll use a larger 7” driven pulley on the torque converter to help the bottom end a bit.
