Welding issues
I was hoping no one would notice but you found out that welding isn't my strong point. You're correct, it is a flux core and I probably haven't cleaned the weld every time like I should. Most of the joints are still just tacked together because I didn't want to weld anything solid until I'm sure it's where I want it. The welder has a High / Low setting and I've been trying to use the high setting as much as possible without burning through. It seems to weld better. The biggest problem is I get into too big of a hurry and I probably should take more time to get a better weld. When it's all done I should probably go over each weld to make sure it's solid.
Thanks for the concern. Constructive criticism and advice are always welcome.
