20 series torque converter carter go kart
Wendle
My torgue converter seems to be working fine. I hit the gas and it goes just fine but the belt does squeal For a second or 2 is that normal. I just got this over the winter and do not know how long it sat.
Wendle
Here are some
That belt looks really loose.
Is there any numbers you can read on the belt?
And while your at it measure the center to center distance on the 2 units of the TC.
Wendle
Center to center is right around 8 1/2
Wendle
Center to center can bee adjusted that back pulley moves with the sprocket
Some one else might have a better chart but I find that belt should have a center to center of 9-3/16 to 9-1/4"
---------- Post added at 04:59 PM ---------- Previous post was at 04:58 PM ----------
If you can't get that spacing you need a shorter belt.
