Kshannon17
Hello!
Sorry for not replying as often as i should have, I have been pretty busy with school and work. BUT i did do a little work on the cart this last week and got the motor mount taken care of!
I welded a plate to the bottom of my motor mount, and then bought some Burris clamps on line. I set the motor in the kart, got the chain straight, then drill holes in the plate so that it would all line up. I then ran a bolt through the clamps and tightened her down, and it works!
I started her up, let her run for a while without the radiator cap and when the motor started to heat up, the coolant went down and the radiator started to burp. I let it run til some vapor came out of the radiator and shut it tight so i think all the bubbles are out.
I will be able to ride it soon, just need to put air in the wheels, brake fluid in the lines, figure something else out for the ignition system, and get a throttle cable!
