1984 IT490 Rebuild thread
modelengineer
Lord of the noise
Sydney, Australia
Only bikes I've ever owned were a Honda 50, and a Suzuki DS-80. Both 2-strokes. That DS-80 was such a great bike. And the NOISE! Took the baffle out of the exhaust and it just sounded epic.
crazycart
RedNek Engineering
MINNESOTA
Cleaned her up. Shes mint.
The head.
jr dragster T
Cold place
Looks like you slipped a few times with the porting tool:sifone: ;) Doesnt look like much gasket surface for such a mean high compression bike.
Kenny_McCormic
Kartless....
Michigan Troll
Lulz at bucket for a center stand, I use a milk crate. Mainly because I can tip the 300lb bike sideways and rock it on instead of having to pick the **** thing up.
crazycart
RedNek Engineering
MINNESOTA
I usually use a custom riveted aluminum stand, but my 200 is sitting on that ATM. I have about 20 of those buckets so i thought what the hell. The 490 isn't too bad to pick up, surprisingly.
jr dragster T
Cold place
Even bigger than a 40 wouldnt hurt if you have the cash. Posably a 42. But the 42 is a pretty massive carb. Do you mean the kind with the square top with the cable routing kinda like a round slide or like what my JR has with the butterfly where the throttle cable attaches.
crazycart
RedNek Engineering
MINNESOTA
If i had the engine ported and i wanted to race it i would go bigger. Some full out drag racers go 50mm+. I'm just using it for a trail bike, with a few drag races tossed in. I would rather have good bottom end than top, especially for what i'm using it for. I mean the kind like a roundslide. The upgraded carb gives it instant throttle response.
jr dragster T
Cold place
Nice carb. Have you ever seen the Billet PSI carbs? Those things are a work of art. There even made for Kenny because they dont use jets! You can adjust them with a driver.
jr dragster T
Cold place
I know a guy with like 3-4 just sitting in a box collecting dust like thats crazy. They where huge, when I saw them I was shocked.
jr dragster T
Cold place
I actually could use a larger carb for my 125. The port looks quite a bit larger then the carb venturi. The stock carb is a KEHIN but looks just like the mikuni 22 I have on my go kart but they differ a tiny bit like bolt spacing on the bowl and such. Would a larger carb give the bike a noticible torque increase threw the mid range? The bike has tons of low end and screaming top end RPM but the torque kinda falls off mid range.
crazycart
RedNek Engineering
MINNESOTA
I think if you got a BRAND NEW carb it would help enormously. New technology is a lot better than 1982's. Id go a few sizes up.
jr dragster T
Cold place
How would I adapt a larger carb to the cylinder head? Also I had to order a new carb to head boot because it was full of cracks and leaking air and the RPMS started to get wild. Kinda scared me lol. I think I'll just stick with the carb I have.
