1978 f150 flareside project
Bluethunder3320
i found that sender. it doesnt appear to be leaking
so got the new water pump in, and new tranny lines. the rear line went in easy, but the front line was hitting against the y-pipe and i had to bend it a little and spent 3 hours getting that one in.
so then i put the radiator in, and it is too small? it said it was for a 400.. pretty sure i ordered the right one but this wont fit. its too narrow so it wont even bolt in.
pretty confused wondering if i ordered the wrong one or they sent me the wrong one...
http://i924.photobucket.com/albums/ad86/bluethunder3320/photo_zpsb88eafed.jpg
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Odd. Did you ever decode your VIN to make sure you have a 400 and not a 351m? I'm not even sure Ford offered the 400 in the F150 that year. I can't find a standard cooling 400 radiator for a '79 on JBG...
Bluethunder3320
nope, im going to go get that now
i checked my order and i did order a 351m rad. but if they are the same engine block i dont see why it wouldnt fit. the hoses are exactly the same, even said 351m/400. but the inlet and outlet on this radiator are too small for the hoses.
Bluethunder3320
size i need:
Core Height: 19 1/4
Core Width: 26 3/8
size i have
Core: 18" x 23 3/4" x 1 1/4"
only one they have that'll fit is plastic :(
devino246
Lynchburg, VA
I hate plastic radiators. I guess you can see if they'll take the radiator back and try to find the proper super-cooling radiator through LMC or Dennis Carpenter.
devino246
Lynchburg, VA
found one on lmc, $250 and its not plastic
never heard of dennis carpenter before
He can be a little pricey, but it's a great source for parts, especially NOS (new old stock). Some of what LMC sells, when you get the box, is literally Dennis Carpenter stock, in a Dennis Carpenter box, in a LMC box. Of course you get the corresponding markup
http://dennis-carpenter.com
crazzywolfie
Orangeville, Ontario
Interesting how the ford 302 Rad matches the requirements exactly. http://broncograveyard.com/bronco/i-20603A-302-1973-79-radiator.html
you can get that exact same rad from rockauto for $123 plus shipping. you can also save 5% off your orders if you use discount code 1283663810490443 . This discount code is good until March 24, 2013.
blue i think you should look check out rock auto. you can get some fairly good deals on some things. just have to watch the shipping and try to get everything shipped from 1 location.
Bluethunder3320
thanks i will check them out. i looked on there before at the time i was trying to rebuild that little 4 cylinder isuzu motor.
heres what it looks like now except i bolted on the water pump and got the alt. and p/s pump on. the water pump had been missing 2 or 3 bolts. i picked up some red and black engine paint and i plan on freshening it up a bit.
devino246
Lynchburg, VA
Well, it looks like some @$$hat got rid of your PVS and decided he was smarter than Ford engineers :censored: Just a heads up, that may cause you some problems.
It's to bad you didn't save up a little more money. While you had the radiator and water pump off, it would have just been a little more work to change out your cam for a RV/towing one and your timing set for a straight-up one.
Bluethunder3320
the rad is still out, i plan on ordering the one from rock auto this weekend
are you talking about the new shiny plug in the water outlet? i put that there because the sensor was broken anyways, no vaccum lines anywhere to be found. and it hit against the fuel line
wouldnt i have to pull the engine to get to the camshafts? or can i access them through that block behind the water pump. i would have to remove that big pulley too right? how much of a job is that?
my local auto store said the cheapest rad they can get will be $500, the rock auto one is $200
