160hp 2 seater
Is a 160hp 900cc two stroke engine enough for a fully enclosed 2 seater built from steel?
  • Total voters
    7
  • Poll closed .
Mr.Nobody
You are going to make it a little wider with a suspension that has a longer travel to absorb the bumps. So that means the kart will need to be longer also. Somewhere there is a ratio for proper length to width starting points. But for the life of me I don’t remember it.
Mr.Nobody
Basically like this but it's a rectangle and not capsule shaped. And a solid rear axle with a dual shock swing arm. Not independant. Cause differentials are for "pro" fabricators.
Look up Edge mini-buggies. They sell everything from kits to plans. I believe they are from your neck of the woods. Australia. So y’all speak the same language. :lolgoku:
