Ok, its a yerfdog that originally had a flat head engine so there would be no problem running that engine at the angle the rear wing arm is slopped at.
Well, with any clone engine it throws the cylinder at an almost horizontal angle. My problem is oil seems to be getting sucked up somewhere and burned. It can't be valve seals as its a brand new engine, and there's never any oil in the exhaust except for one time where I jumped the kart. There is however oil in the breather tube.
I figure maybe it's filling the valves up, blowing oil into the intake cause it will smoke for some time.
I figured I would install a breather and see what happens, but before I go and waste my time I would see if anyone else has had this problem with clones and rough use.
