11hp clone blowing smoke on rough rides.
t0x1k
Vroom
South, NJ
Ok, its a yerfdog that originally had a flat head engine so there would be no problem running that engine at the angle the rear wing arm is slopped at.
Well, with any clone engine it throws the cylinder at an almost horizontal angle. My problem is oil seems to be getting sucked up somewhere and burned. It can't be valve seals as its a brand new engine, and there's never any oil in the exhaust except for one time where I jumped the kart. There is however oil in the breather tube.
I figure maybe it's filling the valves up, blowing oil into the intake cause it will smoke for some time.
I figured I would install a breather and see what happens, but before I go and waste my time I would see if anyone else has had this problem with clones and rough use.
THE HUNTER
"Ghetto Rigging Expert"
Detroit Metro Area
if its tilted, it sounds like its the breather as you mentioned.
you could try disconnecting the breather tube from the intake (plug the hole so dust doesnt get in) and maybe rig up a tin can for the breather to to spray the oil into (if any) so you can see if there is oil coming from the breather in any large amount.
Rickracer
RM250 Race Kart Driver
Kissimmee Fl.
Would it be possible to make an angled mount that would let the motor sit level? I'm sure that would help a lot, and I'd add a puke can to catch the blowby. :cool:
KieranM
Doin It!!
Kilkenny, Ireland
if it had oil in it and it was sitting upside down(wrong way around) for a long time this might be your problem, leave it all drain it out and refill it with clean oil and see how it goes.
t0x1k
Vroom
South, NJ
I figured it out.
The engine calls for 32 oz of oil. There's only an oil slinger, no pump. At 32oz and at the angle it's at the top half of the engine fills with oil fast, and causing blow by. I changed the oil and only filled it to the bottom(maybe 4-6oz less) of the dip stick and it seems to be just fine.
THE HUNTER
Detroit Metro Area
youd better check the oil level VERY often then.
there should be information somewhere about the maximum angle that you can operate the engine at.
Rickracer
Kissimmee Fl.
This would be a lot better idea than running the minimum amount of oil, the minimum amount of oil = the minimum amount of lubrication. With the motor sitting level, it will lube as it was designed to, with the proper amount of oil. ;)
