10Hp Tecumseh Heading to the Machine Shop
solomon
ca
Well i'm heading to the machine shop on Friday to machine the tapered 10HP Tecumseh crank down to 3/4" anything else I should do? I was thinking about milling the block and the head to eliminate a head gasket. I'm using the stock carb and i Plan on using a large low tone muffler to keep it pretty quiet. I am gonna pull the governor, but do you think that stock exhaust will hold the motor under 5000RPM aside from the valve float? Thanx
Kaptain Krunch
Pro Junk Collector
vermont
You cant machine the head and block to eliminate head gasket, you must lap them together.
Valve float will limit rpm, exhaust should not.
solomon
ca
okay well Should i take like .050 off the head and .010 off the deck? Think the rod will hold?
Kenny_McCormic
Kartless....
Michigan Troll
Flathead or OHV? With a Flathead taking meat off the head/deck kills flow, remember that. Floating the valves on a Flathead doesn't hurt anything.
solomon
ca
Im just worried about the rod going, i Have another 10Hp tecumseh that blew the rod with the governor installed and working. It was on a generator too. This motor is a flathead. So all i should do is turn down my crank and remove the governor?
solomon
ca
I have decided not to take off any metal because i want the flow, do you think the rod will hold up at 5500 RPM?
freakboy
the names 'mater
hick town
rod should be good as long as there are no visual cracks.. and the rod cap bolts are torqed to specs.
solomon
ca
okay good. I just lapped the valves a few days ago and honed the cylinder, piston looks good, rings too, has an electric starter, and i have 2 carbs (1 non adjustable and 1 adjustable) and then i will be fitting a series of pipe together to make the muffler attach it looks similar to this one http://ec1.images-amazon.com/images/I/21XFYF5H5XL.jpg but mine is all rusty and such
Blazkowiez
Kart Aficionado
Houston, Texas
See if you can not buy a gel battery instead of a liquid lead-acid battery. It is much safer on karts. Any standard 12v battery will work for you but I highly suggest gel.
sideways
Unfinished projects king.
Perth, Western Australia
Exhausts can limit rpm, many cars can rev higher with less restrictive exhausts and revised or removed rev limiters but I doubt the Tecumseh muffler would be so restrictive to limit such things anyway. If you were serious about performance you'd replace it anyway.
Hayden
Kaptain Krunch
Pro Junk Collector
vermont
Hayden
Thats why i said should not, if it did it probably wouldn't be by much anyways. Not saying it cant, just saying it shouldn't in this case.
many of those little 50cc dirt bikes use a restrictor washer in the exhaust manifold, some of the 80 and 120 sleds do to.
solomon
ca
Its a big bulky silent generator muffler. I'm fine with it draining some RPM. Anything else i should do at the machine shop besides turn down the crank? Thanks Everyone!
