Well i'm heading to the machine shop on Friday to machine the tapered 10HP Tecumseh crank down to 3/4" anything else I should do? I was thinking about milling the block and the head to eliminate a head gasket. I'm using the stock carb and i Plan on using a large low tone muffler to keep it pretty quiet. I am gonna pull the governor, but do you think that stock exhaust will hold the motor under 5000RPM aside from the valve float? Thanx
