1000cc engine
gsegovia
houston,tx
https://www.dropbox.com/s/vg6nmj2e36e4rww/20140414_161417.jpeg
buddy of mine has a 1980s honda motorcycle that he is giving me. According to his knowledge its not chain or belt driven. He said it has a shaft.it is a 2 wheel bike. Looks kind of like a cruiser bike. Can this motoe be changed to be chain driven. Would like to build a buggy with it. And what else can be used on a kart from a motorcycle. Thank you
It can not be changed to chain easily. The internal mechanics of the gearing on the trans and swingarm is all correlating to each other.
gsegovia
houston,tx
Would it be expensive or even worth destroy this motorcycle. I dont want to destroy it and endup not using it. When someone else could advantage from it.
fowler
Bullsbrook West Aus
A member from kiwi land called banjo did change a shaft drive to chain
But if u wanna put it in a buggy then just addapt it to a car diff
It'll be better than a chain drive type
gsegovia
houston,tx
That would be a good idea. But if I did that I wouldn't have a way to put reverse on the buggy.
Canada, AB, Spruce Grove
As said before, a bike like that is too good to just tear apart for the motor. Fix it, polish it, make it look nice then sell it for a couple of grand or more. Major profit than just asking for a motor.
gsegovia
houston,tx
I was thinking a reverse box, but I haven't done much research on it. Am try to go get the bike this weekend. It might not be a bad idea to fix it and sell it. Then I can build the buggy with that money. Thanks
fowler
Bullsbrook West Aus
Yes u can put that engine in that buggy
As for a FNR box
U can get an rpm box
But for the price of it
Unless u wanna get serious in motor sports I'd just put up without it
U would be better adding a reverse motor to the drive shaft
