Quick Bits
Well the new quad is in better shape than the 2 I worked on for the guy. I definitely got the better end of the stick. The frame is straight, the racks arent bent and re-welded. I striped it down and gave it a bath.
So far the parts list is rear tires, a fuel gauge, oil, fuel, and air filter., and a seat cover. I might need a fuel pet 🐓.
The carb was nasty.
Along with the pet 🐓
Then this guy messaged back he has a buddy with a sxs that has been eating starters. I passed on this job, cause it will be a can of worms. Compression release, starter sprag and possible new starter.
Next day he says the original owner of these quads has another that wont start. Wants me to fix it.
Then within a few hours my neighbor calls. He has a quad same issue. It sat and won't start.
Maybe I should advertise and start a business.
Too many hats....
And so it begins. The end of you doing your projects. :ROFLMAO: :cry:
Just a guy, his bear and a Jeep. Oh and lots of 🍺. So, were you supposed to drop the pull tab into the beer before you drank it? I guess the odds of you swallowing it were slim, at least on the first beer but not the twelfth....
How many of you guys have found this guy?
I like his format. Test stock, make one change, test again.
This video is just what I preach. Free power…
Have seen the channel come up in my feed sometimes but have never watched, except maybe 1 or 2, but I have found him. I just recently (2-3 days ago) looked at his playlists matter of fact.
Now that I have your and Edwin’s recommendation and that he doesn’t seem to be a “blast the parts $$$$ cannon at it” or (probably, hopefully) isn’t funded by GoPowerSports, I might hafta watch on your good recommendation. Thanks.
There’s just so much to watch on YT
Another reason I dont care for Polaris.
Lets make the plastics non removable with out removing the handle bars.
Ive got room but sh!ts still in the way.
"It ran 3 years ago when I parked it"
Carbs glued itself closed. Some external brass tube rotted off. New carb and rebuild the fuel system.
The smell is making me sick.
Now its wait on the mailman.
My buddy Ai'd this. I thought it was pretty funny.
