2009 Baja Reaction with a 13 hp clone!
newrider3
Colorado
Better. You don't really need that extra collar between there though. (unless there isn't enough clearance?)
bajagokart
Red Deer, Alberta, Canada
the reason its there is to space it so the belt is straight. the way my engine mount is and how big the driver is if i dont have the extra collar in there the belt will be like a centimetre off
bajagokart
so i did my first official test run and holy fricken crap is it fast!!!!! i couldnt go full speed because it was around my block :p lol but o man i had the time of my life!!! ill have all the extras mounted by tomorrow and then this project will be done!
Cdrew11
Gha I'm so jealous of you right now, I've been trying to get my Yerf-dog 3202 with the same configuration in what seems like forever. It's harder then ever with comet folding and all but Ohh well.
Congrats man, Congrats
bajagokart
lol dude this setup is AMAZING! i couldnt ask for better! im sure you will get it going dude it just takes time! believe it or not this is my first time setting up a TC so im surprised how well it went but ya this thing flys!!!! i definitely recommend using it!
bajagokart
final pictures! go kart is done!
kkmmbb
Denmark
Hi, looks very good! What are these blue things called, that you use for converting? :)
khank1995
Your jackshaft will bend I would add some pipe on the outside of it were it is bare metal between the torque converter and the bearing
newrider3
Colorado
We've already been over this. Look up a couple posts and you can see he moved the bearing up against the driven already.
nerfo
Madison, WI
I was actually wondering how your baja project was coming! I'm glad to see you had some pretty good success with the torque converter clutch setup! I think you'll have way more fun with it! Looks good too!
bajagokart
heres some pictures of my straight pipe! i know, yes the welding job is beyond horrible but i forgot to turn the gas on and i wanst about to start over so w/e its solid that it wont fall off and it has a great sound so thats all i care about!
bajagokart
Thanks! Um the belt starts to sqeak pretty good when I push the engine really hard actually! Idk why the belt is perfectly aligned and at it's set distance of 12 and 5/8" so ya maybe my engagement on my driver is to low but it works good other than that!
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
I surprised you could even get it to hold w/o gas.
