46 ci briggs build up
freakboy
the names 'mater
hick town
Well this may interest some of you but im gona be documenting my tear down and rebuild of my briggs.... its a twin cylinder opposed 46 ci full pressure lubed its a beast hahaha.. Im building this for lawn mower racing so i do have a set of rules to go by.
1. engine must be origionaly manufactured for use in lawn mowing equipment. Must be stock in appearance with the exception of irfilter air cleaner or velocity stack. engine may be internaly modified.
2.exhaust design is open but must terminate away from the driver and competitors in a rearward or downward facing direction and must not present any safety hazard.
and thats basicaly all there is for rules.
so anyhoo now for the good parts pictures hahaha
First picture is the engine before i started riping it down hahah
The rest are durring the tear down... and the last two are sort of a problem.. hey one cylinder is all black and the other is clean... but hey its only been about a hour running them sence the last build... hmmmm something aint right...
well anyhoo i got a few plans for this motor... i already did tear it down before and what not and do a few mods... well now im goin full bore build up cause i was to lazy to do it before...
heres a list of stuff im doing/ have done...
crap i already did
1. Remove gov.
2. Port and polish($hitty job)
3. smooth heads up.
4. some carb mods( ill list them below)
and thats about it.
Carb mods
1. remove choke
2. polish venturi
3. knife edge throtal plate
But for stuff im going to do now
1. Shave eyebrows
2. polish eyebrows
3. polish and smooth heads ALOT more.
4. 3 angle valve job.
5. Better port and polish job.
6. 2 to 1 header.
7. Grind base circle of cam down then extend lifters.(poor mans high lift cam)
8. Drill out oil passages.
Anyone have any other ideas of mods i should do?
i would dual carb it but i dont think i would be allowed to.
freakboy
the names 'mater
hick town
Well over the past few days i worked on one port cleaning it up and im still not done lol.. this is were being ocd sucks. I have one eye brow done... again took me like 4 hours to do it to get it perfect.
Also there are pictures of the heads when i took em off.. both looked like the clean one when i put it back together....
freakboy
the names 'mater
hick town
Ok well now for some of the boring stuff i took my rods and pistons in to school for my freind to mic them for me cause i dont have a set at home... well i get the rods and pistons back and a sheet with all the specs on em... i $hit a brick This thing must have been one UBER low usage engine... everything is within spec and not that far off hahaha.
there the specs.
Piston One
Skirt= 3.433
A measurment= 3.407
B measurment= 3.407
Wrist pin= 0.800
Wrist pin journal on piston= 0.821
Wrist pin journal on rod= 0.800**
Connecting rod crank journal bearing= 1.625
** I dont know how its that but he measured it 3 times and got that the hole time and i trust that his measurements are dead on hes good at what he does.
Piston two
Skirt= 3.434
A measurment= 3.406
B measurment= 3.407
Wrist pin= 0.800
** again he measured it 3 times and got the same all 3 times.
I still need to get the bearings on the cam measured and all that good stuff and the block and what not but it should be good.
freakboy
the names 'mater
hick town
freakboy
the names 'mater
hick town
Well i made a ghetto little flywheel puller yesterday so i can get the flywheel off the crank which i was never able to do before. well its a quarter inch plate with a bolt in the center and two bolts on the outside that thread into the holes on the flywheel worked good i kept goin with the bolt till the quarter inch plate started bending then i taped the flywheel with a rubber mallet and POP the crank flew out hahaha... here some more pictures!
