Briggs 5 Hp Funpower Problem
VaultFan92
all try grease once i take it off and hopefully clean it and try it again and see if it works with the grease. i thought of grease but everywhere i read said motor oil so i figured id ask.
VaultFan92
that's what i plan on doing once i get a chain breaker. also the engine shakes pretty bad, is this bad or normal? it has done it since i got it which was years ago but im not sure if its supposed to do that.
Kaptain Krunch
Pro Junk Collector
vermont
Your spring could be worn, what i did with mine a few times after extreme overheating, was cut a few coils off the spring. It helped ALOT, never took off at idle again.
solomon
ca
the engine probably shakes due to poor motor mounts or low very idle, try turning your idle screw in 1 turn. Why do you need a chain breaker? You can still remove the clutch
VaultFan92
How do i get it off with the chain on? whats he proper way it should be mounted? anyone got pictures off it?
solomon
ca
yup. when you looser your motor mounts (usually FOUR 1/2" bolts) see if their are any rubber Washers in between the motor and the mount, if not go buy some, will stop the shaking.
VaultFan92
well i have no idea what a master link is so i dont know if i have one. and i am pretty sure there aren't any of those rubber washers on there but i think we might have some. how thick should they be?
vgk
Las Vegas, Nevada
http://faq.f650.com/FAQs/Photos/ChainPhotos/MasterLinkTopLeg.jpg
This is a master link. If you push out the side with the cut on it, you can take it off. Behind the master link is a little chain plate and then take out the other side. Chain is then off. Also how bad does it shake? mine shaked because of the badd clutch. If I am correct, when you put the kart on the ground and try to start it with the throtte applied a bit, it will start and shake then die right? If so, you broke a little piece in the clutch.
solomon
ca
vgk is correct on the master link. Don't know about the clutch causing the shake, but it definitely could contribute. Since you don't have any rubber washers on trier to absorb the shake, it definitely will shake. I would use 1/8" thick rubber washers or larger. Should make the ride a lot more comfy :)
VaultFan92
im definitely going to get some of those washers, if i use 1/8" will i have to add any chain to keep the right tensions or is 1/8" to small to effect it? i'll have to look for the master link tomorrow as i am busy today.
solomon
ca
it might make your chain a little tighter, i don't think you will need any more chain
solomon
ca
Yea right! you wouldn't loose rpm. I did this to my kart and nothing happened, except it took all the vibration away.
Kaptain Krunch
Pro Junk Collector
vermont
You will lose RPM, on this scale, it may only be a few, but technically you will. Making statements like that, with no facts to back it up makes you look like a complete ***.
I cant imagine 1/8" rubber washers will do much, and i wouldn't even bother, its likely the ground will shake your kart more than the engine once your moving anyways.
