Clone for $89.00
1992suburban
I wanna go FAST!!
Sanford, NC
.......awaiting the NEGATIVE comments about how they are china made and will blow all apart, and wont last.....
hahahahaha..... YOU KNOW WHO YOU ARE
Kaptain Krunch
Pro Junk Collector
vermont
I dont think they are just going to blow apart, but i do not support buying these chinese engines. I hate buying anything from china, but unfortunately so many products these days are made in china, its sad.
modelengineer
Lord of the noise
Sydney, Australia
Don't buy one, they all blow apart and last no time at all!
Even I have to admit $89 is attractive, but I think it would have to get to $49 before I would consider buying one.
Kaptain Krunch
Pro Junk Collector
vermont
Unless you remove the governor and mod them to go past valve float, its pretty hard to beat on these things. I mean holding it at governed 3600 rpms all day wont hurt the engine at all, generators, tillers, lawnmowers, snowblowers all do.
Orange Krate
North Texas
I keep wanting to try one out but I'm torn. It's not so much the China thing as I like flatty's with steel cam lobes. Asian overhead slants wouldn't be period correct for my junk.
freakboy
the names 'mater
hick town
and its china and they are comies and we are buying all our **** from them when we hate comies aka cold war trying to fight comunism now we are feeding it like a fat pig..
and no one knows how long these things last they havent been around all to long..
EagleTalons
Master JB Welder
Forsyth, Montana
Well, the good thing is Obama is helping us cope with the Chinese problem with the classic phrase. "If you can't be them, join them"
freakboy
the names 'mater
hick town
dont you mean if you cant beat them give them all of our jobs and making our country worse then it was then yes... and also take our guns and freedom take our money and leave spare "change"?
tykenfitz
hey, any you guys holdin on to a 6.5 clone, do you mind taking a couple pictures and putting the dimensions? I wanna see if I can swap it out on my bike.
Thanks
whaleit
Tarpon Springs, Florida
Honda clone Engine dimensions
tykenfitz,
google harbor freight....type in engines on their search bar...select 6.5 HP hor. shaft...model #66015...there is a PDF manual with all info on there...if not there post exactly what dimensions you are looking for and I will post.
tykenfitz
got em, thanks mate :cheers2:
I'm trying to create vertical space. Is it possible to move the gas tank to another location and get a less obtrusive air filter? If so I'd be very grateful for this dimension:
The fuel tanks on these engines unbolt and could simply be remounted to most any point above the carburetor, and then instal a longer fuel line so the gas would still gravity feed to the carb.
Or with the addition of a pulse-type fuel pump, you could re-mount the fuel tank most anywere you wanted below the carbs level.
Lots more Pulse fuel pump info can be found here: http://www.affordablegokarts.com/fuel-pump-setup.php
Here's a link to a race style air filter and carb adaptor for 6.5hp Hondas and clones: http://www.affordablegokarts.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=A&Category_Code=GGPP5
