best welds
KieranM
Doin It!!
Kilkenny, Ireland
well,
I just thought it would be a good thread to start. Lets see who is the best welder on here. Your welding can be any type on any material. What you need is a nice even bead and avoid contamination. Lemegacool has some lovely welds of cans, but this thread will be for welds of all material. Make sure you state what type of welder you used and the material. I will get up some of mine in a little while.
I really hope this thread does not die before it starts.
Kieran
BriggsTwins
Pittsburgh pa-Tallahassee- fl
Ok ill contribute not best, just a HF welder and 3/16 plate
both are vertical stringer and weave
sure will hold though
robin
in a house
im crap at going around pipe but i can do ok welds on straght stuf
this is like a year old tho
i was once told that if its a good weld the slag will start to peal off
oh and i was using a 2mm welding rod on a sealy 180amp arc welder on steel
lemegacool
got boost? :)
quebec canada
lets see...
high pressure ASME procedure 2g fixed position. GTAW-ALU
welded with http://www.millerwelds.com/products/tig/syncrowave_350_lx/
i would love to show you guys my ASME 2" steel pipes welded in 6g with 4011 root pass and 7018 capping but i dont have pics of them :s
same welder as above...
stainless tig welds on my jet engine's end cap... welded with the symcrowave
smaw 7018 weld with the syncrowave
FCAW 1/16" gas shielded wire weld with this welder http://www.millerwelds.com/products/mig/deltaweld_452/
steel tig weld with syncrowave...
rmkrider1
Some decent looking welds guys!!
I'll play
Stainless fillet weld done in my garage real quick with my syncrowave 180sd.
freakboy
the names 'mater
hick town
ok here is my go i helped a freind tig a drag car cage for his nova and that was the best weld all day.
i cant remember what machine i was using
TurtleMann14
Insane plan member
West Virginia
right time for some of my welds. Not my best i have got a bit rusty at it. I was using 6013 on the arc welder. I just really welded it up to see what thickness of steel i would use on my minibike.
http://s742.photobucket.com/albums/xx61/kieranm09/?action=view&current=PICT0001.jpg
http://s742.photobucket.com/albums/xx61/kieranm09/?action=view&current=lok.jpg
for your 60** you need to group tighter... supposed to look like a roll of dimes
stick kinda sucks, but if i am welding anything that i want to be as strong as possible that's my preferred method
mig i can do pretty easy
tig i love to play with aluminum or steel (need to get more consistent)
BriggsTwins
well his welds look good, but it doesnt seem as though he isnt using the proper method
strike it, hold for 1 second, let up (without breaking arc) then as the puddle solidifies touch the rod down to the top of it, and repeat.
- or just weld the way you do, the strength is more than enough
Kaptain Krunch
Pro Junk Collector
vermont
Briggs, i have never heard of stick welding like that, that sounds more like tig/gas welding if anything, the "proper" way i was show is to strike the arc, and slowly move the rod in a zig zag pattern, while moving it in the direction you want your weld to be.
Kieren, i would say just move a bit slower, otherwise your bead looks ok.
TurtleMann14
Insane plan member
West Virginia
how do you guys stay constant? i can't travel and stay constant with a stick worth a crap
right now i am working on a vertical t-joint 6010 at about 67-72 amps and i keep getting lumped up. my teacher likes the top ridges of the weld to be like 1/16" apart.
freakboy
the names 'mater
hick town
go slow and take your time and just relax and listen to the welding sparks and look at the weld you should be able to figure out by sound how the weld is doing.. with flux core i could tell when i was about to blow through cause the sound of the weld.. it sounds crazy but try to pay attention to that kinda thing.
