Anyone know where i can find a 1 inch clutch for a 13 hp clone?
mike75925
thinker and tinkerer
Alto, tx
comet, max torque both carried 1" bore clutches. they also sell tav's with a 1" bore driver. the kits are 169 on avg. the big clutch you need is around 80 last time i saw them
Kaptain Krunch
Pro Junk Collector
vermont
Get a torque converter, if the kart in your avatar is the one your shopping for, a centrifugal clutch is not up to the job.
I believe newrider is selling a 40 series torque converter set up pretty cheap.
bajagokart
Red Deer, Alberta, Canada
that is the go kart im shopping for but i just think im not really gunna do too much offroading with it i just want a toy to have a bit of fun with so i thought a clutch set up would be alot nicer and easier
Kaptain Krunch
Pro Junk Collector
vermont
Im sure the ratio will be lower than 6:1, im not saying a clutch wont work, im just saying a torque converter will be worth it.
andrew
Cary NC / aagrena@gmail.com
hi if you want a totaly bad *** clutch for your 13hp,look up the Noram Enforcer clutch.i ordered it for my 16hp and it works like a charm.as you were saying this clutch has a 1inch bore, 1/4inch keyway,and up to 40hp!!!!!!!!!!! the only thing that i was disapointed about is that this clutch mounts on the end of the shaft but in my case thats okay ......hope this helps
redsox985
PA
Please, check the date when the last post was made before posting, and consequently bumping a thread. The clutch was available on Jan. 22, 2010. Good luck getting it. If you must search to find a thread, don't post to anything older than about a month unless you contribute some important info. Otherwise welcome, throw a thread into the new members area and brief us on your kart.
