Thanks Briggs. You know I will!!NICE pictures, keep em coming!!!!
I couldn't agree more. I learned a while ago that there's just some things you hire out.I love sandblasting.
Well doing it sucks, but the result is awesome
if you take a peice of string and go from the top of the king pin and to the center of the rear axle you bend the spindle arm to follow the string and drill a hole on there were the string is. then that should do it.
OK, hypothetical question: On a steering setup with the pitman arms pointing to the rear, the tie rod attachment piece points downward. On my kart with the pitmans facing forward, the attachment piece points up. Therefore, in my case, if I use the attachment piece with two holes, shouldn't I cross-mount the tie rods to achieve some Ackerman-effect?
And Eddie, I see the holes for your pedals. Won't they will cause interference between the drivers leg and the tie rods?
Nice article! But would the tie rods mounting to the steering shaft in two separate holes like you did also work when the pitman arms are in front as originally done on the Rupp? (as opposed to rear mounting like yours.) My concern is that my live axle kart with no Ackerman would plow terribly.
Actually, if a kart has a drag link/tie rod set up, where the tie rod runs from spindle to spindle and the drag link runs from pitman arm to one spindle arm, proper ackerman geometry is still doable, but it has to be set with steering arms coming off the spindles at the proper angle (center of king pin to center of rear axle... this has been beat to death now.) And if your steering arms come off the front of your spindles, then it's the same angle, just faces the front of the kart, not the rear. This type of setup has been used on solid axle vehicles (i.e. straight axle 4x4's) for years. The ackerman is not adjustable with this set up, but really, as long as it's dialed in with the wheel base in mind, there shouldn't ever be a NEED to adjust this. Ticky stuff!
