My first welds?
archer1232
Toronto Canada
These are some of my first welds. Im using a 90 amp Easy mig 100 from harbour freight. what do you guys think.
imSRB
inwood, WV
not bad, but try a corner weld, if your going to make cart your going have make some jus saying.
dowies
Milwaukee Wisconsin
Clean metal = Clean Welds. Get that metal ground clean and you'll get better welds. The cleaner the metal, the better the ground which helps as well. A master fabricator at a motorcycle company showed me these tricks years ago. Granted, there are other tricks as well, but good clean metal is critical. Also, use good 1018 CR steel. Junk HR steel, and plated steel does not weld well.
1992suburban
I wanna go FAST!!
Sanford, NC
true about HR steel.. you can take a flap wheel and get the slag off before you weld HR steel. but the flux core should burn through.
try a fillet weld.. now thats the most common weld. try and make sure the weld is convex, it will help you develop better welding skill (if you ever have to hold a spec.)
but try Higher AMPS lower speed wire.
take two pcs and try to weld them into a 90 degree angle pc then beat it to death with a hammer see how strong it is.
lemegacool
got boost? :)
quebec canada
not to be an a s s here but in semi-automatic welding amperage is directly proportionnal to the wire speed... so more wire = more amps and less wire = less amp... semi machines are CV (constant voltage)
its all a combination of voltage and wire speed that give you a final amperage...
in this case i would only crank the voltage... but again to properly determine if you have the proper setting its always better with the gun in you hand! lol its hard over the internet
t0x1k
Vroom
South, NJ
Clean metal = Clean Welds. Get that metal ground clean and you'll get better welds. The cleaner the metal, the better the ground which helps as well. I usually clean my metal with brake cleaner after it's ground to remove all grease / oil as well. You'll get even less imperfections. A master fabricator at a motorcycle company showed me these tricks years ago. Granted, there are other tricks as well, but good clean metal is critical. Also, use good 1018 CR steel. Junk HR steel, and plated steel does not weld well.
Before you weld again, please read this article regarding brake cleaner and welding. It's worse than welding galvinized steel.
http://www.brewracingframes.com/id75.htm
