Sparkly Oil?
kibble
I banned myself
It probably wouldn't make much difference anyway because these small engines aren't high compression engines.
oscaryu1
Being that the engine didn't smoke I think it is just wearing the cylender down from a very tight factory fit. If the engine started to smoke I would be concerned. I will probaby put some restore inside though.
You should be concerned about your rings eating your block...
oscaryu1
It won't. Restore with CSL is made for car uses. Not for small engines... Small engines can have anywhere from 1/3 to 1/5 of a cars comprssion... (Around 200PSI)
oscaryu1
just chekc oil often and chage again in 10 or so hours.
That would make no difference if it was a internal problem...
You should never have sparkly oil... or oil with visible metal bits. If it does, then somethings been grindin down in there...
oscaryu1
When you break a engine, it shouldn't grind itself to pieces during the process.
