Rickracer
RM250 Race Kart Driver
Yes, it will lean the motor out a bit,
I've used both K&N and Uni (each corectly cleaned and oiled) on a very dusty dirt oval kart track and found equal amounts of dirt residue stuck to my carbs bore that had obviously passed right through each of these filter brands.
If your serious about making either one of these filters work way better I'd suggest using a prefilter (or outerwear) sock that fits over the filter: http://www.outerwearsracing.com/ They truly help both of these filter brands to work way better.
I meant on the cover so more air got to the filter. Not below the filter on its way down to the carb. lol If I did that where we ride Id be lucky if it lasted 30 mins! hahaI see someone earlier in this thread mentioned drilling holes in the airbox. Hopefully you are not doing this between the filter and the carb because the results will not be good. Dirt and engines do not mix well.
