Jeff Kellogg
- Messages
- 1
- Reaction score
- 1
What is the advantage of using an air box over just a K&N filter directly attached to the carb?
Airboxes do not filter air. Filters are used on airboxes.
if you put a k&n and a mikuni you will win up to 1.5hp but this only work if you use the top of the line model(90$)
When I switched to an open air filter it was actually more of a worry than it was added power. I had to get an outerwears water repellent cover and it doesnt protect from fine dust as well (especially UNI). If you have an engine with an air box like the honda's, clones, and subaru's and all and want some extra air flow you can drill some holes in the front and on the sides. It obviously still wont flow like an open filter but it will be a little bit better. I think that's what Im going to do with mine. To racers its not really a problem, but if you just ride the trails you sometimes need to sacrifice some power in order to keep your engine and carb clean and safe.Forget both of them, get a dual stage UNI.
no u won't.
Over a 1 1/2hp increase has been reported with some engine combinations
