A New member joining for your view's, and good guidance.
Talisman
Hi, DIYGK Members.
I am currently working on this project, an idea slightly different in wooden diy go-kart frame builds. I've attached pictures of my prototype to share, your comments will be greatly appreciated, if not useful. So please feel free to express your thoughts. For now I will be posting photos, so you can say! what you see in the pictures and join in the thrill, helping making a little surprise this Christmas for my two, four year old grandson's.
I will also be posting again with the following, sizes and materials etc
Many thanks and looking forward to hearing from your end.
I like it. It has the flavor of a streamlined soap box racer or similar.
What kind of powerplant are you thinking of? I bet it’s electric.
:welcome2:
Talisman
Hey Talisman,
Looks pretty kool...so far :thumbsup:
What ya using for wheels?
...what are ya using for spindles & an axle??
...& how are ya mounting them???
Hi Functional Artist, I'm working on the parts I'm going to need and using AI to get the information to my prototype design. So will be greatly grateful to any help Members could give. I will put a list together soon and also the specific size of the build. Putting a sketch together at this moment. 👍
Right. Add that sketch and the way you intend it to look and the forum can provide some parts sources. What kind of landscape do you intend for the kart? Pavement/sidewalk roads, grass, dirt, rough stuff?
You’re in good hands with Functional Artist though.
Talisman
At the front I will be sandwiching Douglas fir cross beams and layer two steel plates, flitch plates over both timber faces. The back one timber cross beam under the bottom and a steel plate. The timber will be the exact width and the metal plates a 100mm longer each ends. To mount the axle brackets onto.
Talisman
Sorry I've got to get used to replying i sent it as a message
Talisman
Done see below or my thread will reply to individual posts next time
As long as you keep this thread going, we can follow along.
Just start typing in the box.
No real need to hit the reply button.
But you can "multi quote"by stacking the reply button and replying in-between.
GDFPlayy
Hi, DIYGK Members.
hello I am also new here on this forum
Trying to follow along here. Don't know if you are looking to put on bigger tires or if that was just someone's remark. Bigger tires and sand put a tremendous load on the drive train compared to most other terrains. That might be a problem if your electronics are not up to the tasks.
Talisman
Yeah, I didn't get the tyre remark and thought it was for someone else's chat. I'm waiting for a call to pick up my mild steel metal flitch Plates.
PLAN IN PLACE: As Listed Below.
Front x 2 @ 450 x 65 x 4mm these will sandwich the top and bottom floor pan Douglas fir timbers members I've shaped over and under the wood slated timbers, that are 350 x 70 x 25 The plates will leave me 50mm overhang left & right. a 60mm space I'll push a wooden block in then drill 11mm holes to bolt down spindle bolts stub axle spindles. 300mm adjustable tie rods dual hole pitman arm on column.
Rear x 1 @ 320 x 130 x 4mm to mount for a 600mm x 20mm shaft dia rear live axle kit, UCP204 Pillow Blocks, #420 Sprocket and brake disc completely outside the timber.
Wide off road tyres and wheels size:
145/70-6 (14 tall, 5.7" wide
Heavy duty steel rims and 4 stud bolt pattern.
Does this all sound okay to work.?
Cheers all
Talisman
I THINK BAD THINKS SOMETHINK ELSE🤣
