Celerity Quicksilver Sport Coupe (EA racer)
I've been workin' on a new style of EA racer
This one will be named Quicksilver
...& the design/style of this racer will be referred to as Celerity
Celerity (class) a group of vessels built to the same general design
Quicksilver (designation) an official name, title or label
This is a rough drawin' of the Sport Coupe style, that I have in mind
I'm going to try-n-incorporate roughly the same seatback & floorboard style angles & dimensions, of the Granite (monocoque) racer
...&/also, use them as an integrated internal triangulation method
Maybe kinda like this (mock up)
Initial idea mockup for the integrated internal triangulation method
The seatback & "tail" are on the left
...& the footboard & "nose" are on the right
Different view of the seatback with rear "deck"
Profile view of the seatback & rear "deck" area
A mockup of the integrated internal triangulation method
...with overall body concept
* Notice how the integrated internal triangulation method will help support
...& maintain the shape of the outer body/shell?
The rear wheel should go about here
...but, will be ~4 lower
A mockup with the integrated internal triangulation method
...& a side panel
* Notice the potential windows?
Hints of Giorgetto Giugiaro. I like it.
Hey Ez,
Never heard of that guy
...so, I looked 'em up
Giorgetto Giugiaro’s “Folded Paper” Auto Design Era​
Giugiaro’s “folded paper” style is a 1970s–early 1980s design language defined by sharp creases, geometric planes, and crisp edges, marking a decisive shift from the organic curves of the 1960s
Origins and Development​
The term “folded paper” refers to Giugiaro’s signature angular, planar aesthetic that emerged after his time at Bertone and Ghia, and was crystallized during his 1968–1970s run at Italdesign, The style’s roots can be traced to the 1967 De Tomaso Mangusta, which introduced flat surfaces and sharp lines, replacing the flowing curves of earlier Italian sports cars. Giugiaro himself later said he needed a distinctive style so clients wouldn’t think he was simply copying his employers.
He's the guy known for the "folded paper" automotive styling design/concept
He designed the "Back to the Future" Delorean
...& many other famous cars (& cameras, wrist watches, guns & pasta shapes too)
He's a FUNCTIONAL ARTIST :sifone:
Yup, I'm thinkin' & workin' with "flat surfaces and sharp lines"
...but. I'm also, try-n-to incorporate some "flowing curves" into this racer, too
For this mock-up, I'm using wood panels, for the flat surfaces
...& am just bowing them, to produce flowing curves
Aerodynamic body shape commentary:
The floor is mainly a full length, flat panel that goes from the "nose" back to the seatback
...then, gently curves up to the "tail"
The hood/roof is also, a full length flat panel that goes from the "nose" until the apex of the roof
...then, gently curves down to the "tail"
The idea is to gently part the air
...let the racer slip thru, without much disturbance
...& then, bring the air back together nice-n-gently :thumbsup:
Specs.
The "nose" is ~8" tall
...& angles back just a bit
The "tail" is ~4" tall
...& is mostly perpendicular
The overall height (goal) is ~30" (~2 1/2')
The overall length will be ~96" (~8')
So, we have an overall shape (body)
...& an integrated internal triangulation method (spine)
* The integrated internal triangulation method will support & strengthen the body
...&/also, can be used for securely mounting & supporting the battery, seat, motor & axles
Next, up would be designing the sides
...& determining the overall construction method, that we are gonna use, ta bring 'er all together :cheers2:
Inspiration:
I was sitting behind a Toyota, at a traffic light
...& noticed that the "sides" curved at the top
...& then, connected to the roofline via some black (plastic) strips
Suddenly "envisioned" connecting the "sides" to my racer, kinda like that ;)
Then,
Thinkin' it thru, figured I could construct this racer using the Unibody method (also, like the Toyota)
Unibody (Unitized body)
A design & construction method where a vehicles body, floor pan & frame are built as a single, unified integrated load-bearing shell.
The strength comes from an internal network of stamped steel panels, box sections & bulkheads
...rather than just a thin outer skin
Inspiration:
Kinda like this
or this
DIYing stamped steel panels is very difficult in a backyard setting
...& the resulting structure would/should be (IMO) kinda heavy
...but, I can mold just about anything outta fiberglass
...& then, bond 'em together :thumbsup:
So, to make a "side" mold, I propped a sheet of 1/2" MDF against the side of the mocked-up body shape
...traced the outline
...cut it out
...& then, added some ~4" side flanges on the underside
Kinda like this
* Most car sides are kinda rounded or curved, from the top to the bottom
...& from the front to the back
In an attempt to accomplish this compound curving, with flat sheets of wood, I cut a second side panel
...split 'er down the middle (kinda)
...inserted a 2" wide x 48" long piece of 1/2" MDF (centered on the lower panel & along the center seam)
...& then, bonded the top panels down to the lower side panel, around the perimeter
This should produce a mild body line & slight curving of the side panel
Yup, some body work is needed, where the flange, broke while curving, during installation
Left body side (in the rough)
...propped up to the body mock-up
...with window cut-out drawin' on it
Another view (haven't "capped" the ends or done any roundin'...yet)
Another view
* See where the sides & the top...meet up?
...& how a gently curved, flat panel could "tuck" right up under the flange, along the entire length of the body side
Can ya see the slight curvature of the body side...in this pic?
** Also, notice that there is ~1" of material to "work with" ta curve the perimeter of the body side??
See where I gotta trim & then "cap" the front end, of the body side?
...& add a bit of an extension to the flange
* Hi Ducky :)
Trimmin' & cappin' off, of the front & rear of the body side...are done :cheers2:
Next up...roundin'
* I have ta try-n-maintain an even "roundin' off" of the body side ('cause I gotta try-n-make another exact opposite copy, for the other side)
So, I first "trued up" the (2) layers of the side panels, with the flange (usin' a 36 grit sandin' disc)
...then, ran a router around the perimeter (to evenly remove ~1/2" of material, from the edge)
...& then, again usin' the 36 grit sandin' disc, I rounded off the entire perimeter, as evenly as I could (all the way around)
Next, I switched to the palm sander (w/120 grit paper)
...& smoothed off the rounded edge (mainly removing the sanding scratches, from the rough 36 grit disc)
...& then, switched to 220 grit paper & smoothed 'er off even more
Then, "blew 'er off"
...wiped 'er down
...& gave 'er a good coatin' of Satin Black spray paint
* No pics...of any of these procedures...misplaced/couldn't find the camera...all afternoon :confused:
Yup, them are "nose" & "tail" molds...in the background
The "nose" & "tail" molds are just simple shapes, matching the profile shape, of the "nose" & "tail" of the sides
Here are some initial drawin's (changed 'em a bit durin' the process)
Another view of the "nose" & "tail" molds
...also, with (2) layers of 1708
Why do you use such thick materials for your buck? You would be better off using some 1/4” or lesser plywood or cheap paneling. This way you could add your curves to the body quite easily. Maybe even add some slight compound curving?
Hey Denny,
Personal experience/preference
1/4" material
...doesn't hold fasteners very well (fasteners pull thru on the flats & tend to split the material on the end grain)
...it flexes during sanding (it's hard to "work" with flexing material)
...doesn't have much "bulk" for edge rounding/sanding (& when sanded the flexing gets worse)
...& it tends to fail during de-molding
I've documented...all of this...haven't you been following along?
Here's the right body side mold (in white satin)
...coated in PVA
...& ready for fiberglassin'
* Notice the piece of 1" melamine
...& the left body side, after trimming, in the background
Another view
* The ~4' x 8' piece of 1' Melamine, is to make FG flat panels (like for the floor)
FG resin doesn't stick to Melamine very well
...&/so, it doesn't even need any PVA
** I found it in the discounted/damaged wood bin, at my local plywood store, for $9.95 :wai:
It had some banding strap deformations along the sides
...so, I just had to trim ~1" off of each of the long sides
Hey Denny,
1/4" material
But if you use wood cleats say 1”X1” at the joints there’s plenty of area to screw to. Back off on your sanding pressure if the board is flexing. Let the sandpaper do the work.
