Dangerously Sensitive Steering (Thunder Kart)
icer22x
I am in the process of fixing up this Thunder Kart for my kids. After modifying the 212, I am focusing on the steering now. I reluctantly allowed my 12 year-old to drive this for the first time and he almost crashed it due to the horrible steering. Almost gave me a heart attack. Thankfully he wasn't going that fast and had enough sense to listen to dad and let off the throttle and apply brakes.
The steering in this cart is as the title says. If you so much as breath on the steering wheel, the cart is turning. It's also pretty difficult to turn the wheel; requiring more force that it should... so it's very easy to over-steer (which was the cause of my son almost crashing). When this kart gets up to speed, you have to provide micrometers of steering or else you're going to have a bad day.
Where should I be looking to make adjustments/modifications? I have seen people on here suggest crossing the tie rods on the pitman arm. I've also seen the suggestion of drilling new holes in the pitman arm closer to the steering column.
Sparkwizard
Richlands ,NC USA
Can you post a picture of the spindle where the tie rods attach? Moving that pivot point away from the kingpin /bolt will slow the steering down.
If there are more than one hole, move the tie rod away from the pivot. If no more holes, extend the arm by welding (preferred) or bolting an extension to the lever.
Thepartsguy
Did you add you own tie-rods and bend the square piece downward? This is how most of my karts are setup and it’s the factory way to do it.
The way your karts tie-rods are run is directly wrong in my opinion.
His steering looks proper for a Brister’s Thunder Kart. The Pittman arm plate, or whatever that is called, is bent or angled from the factory.
Since it is so hard to turn the wheel, every pivot point in the steering should be lubed generously with a few drops of fresh engine oil or something with staying power (3-in-1 oil, etc). Original formula WD-40 is little more than a solvent. It may be necessary to “work in” the lubricant by turning the wheel full lock to full lock in both directions several hundred times. 🥵
This is Carter Brothers' (a competitor kart manufacturer) service recommendation:
KART LUBRICATION - Every two or three hours of use lubricate the following items with several drops of oil; steering bearing points, brake rod pivot points, pedal pivot points, steering spindles, and steering rod ends. Use the same grade of lubricating oil that is used in the engine crankcase.
It might behoove you to disassemble the front steering components, the spindles, spindle bolts, rod ends and assess the condition. Rust and pitting is your enemy and which causes excess friction. If the spindles are rusted and rough on the inside diameter, you could clamp a phosphor bronze/copper or steel bore cleaning brush (20 gauge shotgun brush?) in a drill chuck and go to town on the rust. Once clean, slather the spindle and bearing surfaces in a quality grease and reassemble. As mentioned before, a regular oil on the rest of the exposed parts is your friend.
So it turns nicely and quickly huh? I see you have a one-wheel-drive kart which has by nature a poor man’s ‘differential'. It’ll turn but at the same time the driver must use DISCRETION and drive carefully with some finesse and pre-planning. Just be glad it’s not a live axle, that kind of kart just wants to go in a straight line.....
Those socket-over-ball tie rod ends are not my favorite as they cannot be lubed easily (they are upside down and have a rubber seal), and when they wear out (the ball hogs out the socket) the socket pops off the ball and you lose your steering. Can be a real bummer out on the trail.
These heim joints (or ones like it) in my humble opinion are superior. They are easy to lube and will stay assembled as long as there’s a bolt going through the ball *(and a nut on the end):
He might just be the problem. He’s a first timer and you were reluctant (that might have been your gut instinct giving you a warning). Sounds like a slightly troublesome scenario to me. Again, Carter Brothers:
TURNING MANEUVERS​
The new rider must learn to shift his weight and control the throttle to allow the rear tires to negotiate the turn. This is the primary technique to be mastered in riding this vehicle. Practice turning at slow, constant speeds. Defer increased speeds until you are confident of your proficiency and are intimately familiar with the terrain.
Steer in the direction of the turn, and lean your body to the inside of the turn in order to maximize front tire traction. Use the throttle to maintain power throughout the turn.
Once this technique is learned, turning maneuvers can be performed within a relatively small area.
Incorrect turning techniques may cause the front wheels to slide straight ahead without affecting the vehicle's direction of travel. If this should occur, come to a stop, then resume the technique outlined above.
If the front wheels tend to skid in mud, sand, or snow, you may be able to improve control by releasing the throttle and allowing the vehicle to coast through the turn.
If the rear wheels inadvertently skid sideways, correct your slide by steering in the direction of the skid, if you have room to perform this maneuver safely. Avoid braking or accelerating until you have control.
To avoid skids while traveling on slippery terrain, the rider must exercise a high degree of caution. Turning maneuvers on slippery terrain are more hazardous than those performed under full traction and must be done slowly.
Surface composition is a major factor affecting skidding. It is easier to slide on packed snow than in deep sand. It is dangerous to skid on ice, because you may lose all directional control, and it is dangerous to skid on pavement, because you may regain traction suddenly and unexpectedly, which can cause the vehicle to overturn.
All that High IQ driving stuff being said, lube the steering and keep it greasy. 🛢️💧
icer22x
As requested.
icer22x
I’ve made no mods to the steering. Must be from the previous owner. Thanks for the picture.
icer22x
Thanks for the info! My next mod is to slap a live axle on this kart.
That will slow the steering down.
I wanted to say it so bad, Denny. 😀
It won’t steer any more, at least easily. The tendency for a live axle kart is to plow straight ahead with the wheels at full turn. I think they used to call that understeer back in the dark ages. Turning is accomplished with lots of power so you better be already going fast into the turn, and because all the friction from the outside tire having to rotate more than the inside tire, it has to slip or skid because the axle is solid…. that bleeds off lots of speed.
My advice is to just keep it the way it is. It’s already a mostly flat-surface, packed dirt, developed-trail or pavement kind of kart. No suspension like the new China buggies or later Yerf-Dogs, Murray Explorers and the like, so you might as well not punish yourself or your kids on the rough stuff. So it doesn’t need two powered wheels for offroad traction. *You can still run offroad. There’s several videos of people on one-wheel-wonders doing fine in the weeds.
Put some slick or ribbed tires on it and pound the empty parking lots at the abandoned mall or the neighborhood streets. ThePartsGuy will salute you, lol.
Read Turning Maneuvers again in my post #6 above. I believe that was primarily written for the live axle folks.
The live axle understeer can be negated to a large degree by having a heavier rider. You have kids but go karts were developed by men for men, even with their knees all scrunched up under their chin, so a +/-180 pound rider will add weight to the front and make it steer better. Then the rest is Body English, weight transfer, leaning into turns, power application, etc.
Since you have kids, plural, it’s time to buy a second (and third?) kart. Why not buy another kart that’s already a live axle, then you can have the kids compare and contrast the two.
The pitiful one-wheel-wonder has been relegated to the low cost/entry level fun kart lineup for a long long time but the first go kart developed by John Arthur “Art“ Ingels was a one-wheeler and so were many thereafter. Teach the little tykes some restraint on the right pedal, fine motor skills or finesse or just invest in a large supply of spare tires for that wheel… :cornut:
