wanted
haru7713
I am looking for the brake system for the Runner 83-84/ch/08.
haru7713
Heres another site with the same catalog.
Are you looking for exact replacement parts?
Could something more readily available be used or modified to work?
Tell us more about your issues.
I sent an email to Haase a week ago, but I still haven't received a reply.
If it helps keep costs down, you may use parts from other models or consider simple modifications.
haru7713
You have a shifter kart with front & Rear brakes, right? ~ If so: You might try contacting a company called Shark Shifter. They specialise in shifter race karts and might have rebuild-kits and/or new replacement master cylinders available for your application. https://sharkshifter.com/
This is an automatic kart with only a rear brake; it is push-started.
So you need a master cylinder and a rotor?
Rotor shouldnt be too hard to find. Diameter, thickness and bolt pattern.
The master cylinder should have a common sized mounting pattern. Any brand or style that fits should work.
