Help With Pulley Alignment on predator 212 / YD3203
bigboi86
Have a YD 3203 just bought. It has a predator 212 on it. Got it home and as we are driving from stop, it has issues lurching or jolting, it appears the pullies are not aligned and it’s causing the driver pulley to grab the belt, causing the jerkiness
holding a straight edge against the flat side of the driven wheel pulley, there’s somewhere around the 3/8 inch gap between the straight edge and the flat side of the driver pulley
So it looks to me like the driver pulley needs to either move away from the engine about 3/8 of an inch or the driven pulley needs to move closer by that distance, or they both need to be moved to close the gap and align the flat sides of the driver and driven pullies
But, there is only maybe 3/8” left of the spindle(?) for the clutch contraption to sit on, so if I added 3/8 inch worth of spacers, or probably really any more between the driver pulley and the engine, there won’t be enough spindle (?) for the clutch to sit on.
sorry, I don’t have a lot of experience with small engines like this or go karts, but I’ve always wanted one and my boys are ready for me to get it running right!
Sparkwizard
Richlands ,NC USA
Can you loosen the bolts holding the engine down to the frame and move the jackshaft plate? It looks like a seperate plate between the engine and the frame. Adjust your alignment, adjust your chain and your belt and tighten the bolts. Look at that and if that doesn't work, wait for someone smart to chime in.
Someone just did: you. The rest of us are idiots. 😆
Your driven pulley, for one, should be immaculate and polished smooth but I see crusty rust in there. That’s not good for the belt’s health so it looks like it’s time for a service interval …which should be do-able with these torque converters. And I agree with the jackshaft assessment mentioned above, if it can move and correct the problem, that is.
Good photos, by the way
Original engine was a Tecumseh OHV 5 or 6hp which probably had slightly different geometry, had a longer shaft than that awful Rotaderp. meaning that when the original engine was bolted in, the engine shaft was better located to where the pulleys and sprockets all lined up perfectly. No telling how long the kart has been operating in this current state. Probably chews up belts on the regular…
Yerf Dog 3203 Owners Manual:
It looks like you have some kind of spacer between the sprocket and the driven clutch. The sprocket and clutch are both keyed to the shaft. Get rid of the spacer ( or whatever it is ) and replace it with a washer about .050" thick. You will have to cut a slot on the inside of the washer for the key. One washer may not be the exact distance needed, but I think you get the idea. You have plenty of wasted room taken up by that spacer to fly your alignment problem.
If that is not a spacer, and is part of the sprocket, there are sprockets available with different shoulders. Or you could have it milled down. There's nothing you can do on the engine end. The shaft of the predator is too short. I've been down this road on 2 or 3 karts. Move the driven over. You don't need that much space between the chain and the clutch. Spell check B S. To fix your problem, not fly your problem.
I have taken notice of this statement many times before but have yet to measure between engine families to compare, or in other words to prove it to myself; aka seeing is believing. Thanks for the reminder
JimD
Naperville, IL
You are correct , you definitely have an alignment problem. Take the spacer off the crankshaft because you don't have enough shaft for the 4-spline to fit on the end of the crank. That 3/4" spacer next to the crankcase behind the flat sheave has to come off. Get the driver fixed first then let's tackle the driven unit. You can gain inward movement of the driven by doing a couple of things. The sprocket on the jackshaft doesn't need set screws so you can shave that off in a lathe or with a flapper disk. All the sprocket needs is a key the length of the sprocket once you trim it down. The key has no where to go so that is why you don't need the set screws. Some genius put that sprocket in as a replacement and that is where the problems started.
And they are very good pictures.
If you move the driver closer to the engine as recommended in post #8 ( good idea ) your alignment problem will be worse. Probably an inch to an inch and a half. In this case go to the OMB Warehouse, or Go Power Sports website and find their aluminum motor plate. It's a half inch thick and bolts to your existing motor mount ( where your engine presently sits.) It has 4 bolts protruding upward onto which you bolt the engine. Everything is slotted and it allows engine movement for and aft, as well as side to side, by about 2 inches. They cost around $40 and will fix the problem. If I wasn't so technically challenged, I would post a link. But I don't know how to do that.
Sparkwizard
Richlands ,NC USA
I have used those plates. I believe they are for bolting the small 79 and 97cc (DB30) engines onto a standard size frame, or bolting a standard size (212) onto a small bike that had the tiny engine. There might be one for mounting a standard size engine onto a standard size frame, but I haven't seen it yet.
While you're on that site, look for a sprocket fro a torque converter kit. It will be narrow with no set screws.
I have used this plate for bolting on predator 212 and 224 cc engines onto large 2 seater karts that previously had engines with longer crank shafts. I needed to use them because the short shaft wouldn't allow proper sprocket alignment. The exact problem the O P is experiencing. I really don't know anything about the 79 and 97 cc engines. The bolt pattern matched the kart motor mount, and the predator engine footprint perfectly. I would not have recommended them if it was a questionable solution.
Spark, you are absolutely right about sprockets available with different shoulder widths
( as I pointed out in post #6.) That could fix it, if he leaves the driver as is. If he moves it inward as recommended by JimD, then it will take more than a different sprocket to rectify the misalignment.
JimD
Naperville, IL
BigBoi -- all the advice you get here is free and it is all good. The set up you have is much better than the bolt on series 30 because this one you have has a LOT more flexibility. You can mount either a series 30 (which is what you have now) or a series 20 which was designed for go karts. The series 30 was really designed for mini-bikes with limited space. A series 20 run a lot cooler than a 30 because you are not forcing the belt up the flat side of the sheave.
I 100% agree the series 30 is much easier to work with and many of the kart manufacturers used it mainly because it was easy to get and and put on and it didn't take any engineering. The companies that made their own jackshaft arrangement had a much better unit and less problems.
How about a couple more pictures? Would like to see more from the back so I can see what is on the right hand side of the engine (besides the pull start). Is the jackshaft 5/8" or 3/4"? Is the axle fully keyed if you wanted to move the axle sprocket to the other side of the engine. We are all working with you on this project and when you are done you can get your engineering degree you always wanted from the school of experience.
Sparkwizard
Richlands ,NC USA
I never thought to use the plate like that. I assume we would put one bolt down into the frame and one up into the engine, in the same slot all the way around and ignore the four slots in the middle?
*edit* I see a note on the site saying "Drilling four holes may be required." That makes sense, now. Sorry for my confusion.
Going to try to clear up any confusion about the usefulness of this plate. Just so happens that I am switching engine on one of my karts that I use the plate on. Plus I got a smartphone yesterday ( Pancho enters the 21st century) and maybe can post a picture. You can see how the slots allow a full 2 inches of movement. No drilling, just install with upward bolts, lay flat on original motor and install downward bolts. Engineered quite well and will work ( without modification) on anything that originally had a common small block engine.
Sparkwizard
Richlands ,NC USA
Please excuse my ignorance again. I have used several of these and the ones I recieved had a shoulder machined into ALL of the grooves, so a bolt could go in one direction for the larger, outer slots and and bolts would go in the OPPOSITE direction in the inner grooves.
Four bolts down, four bolts up. I don't want to argue, but look at your own pictures. Those are two different bolt patterns and eight holes.
Yes, two different bolt patterns. The ones that go down into the karts motor mount allow for and aft movement. The ones that go up allow for side to side movement. All of the slots have a shoulder milled into them to keep the bolt heads from turning when you are tightening the nut. I don't think we are arguing about anything. The point I am trying to make is that the plate allows engine movement to the side ( either way ) when the axle sprocket can't be moved, and without cutting or welding. Easy bolt on fix for what seems to be a somewhat common problem. On this particular kart, with independent rear suspension, U joints on each axle, moving the large sprocket was impossible. Original 196 clone engine had a 3 &3/4" crank shaft. Put the Predator on there with its 2&3/8" shaft and was immediately faced with an alignment problem. I had to move the engine to the left about 3/4". Just trying to point out to others that there is simple $40 solution when sideways movement is necessary.
bigboi86
Man thank yall for all the suggestions! I ended up deciding to try the motor plate route at Pancho’s
suggestion and ordered a few different adjustable motor plates off Amazon (so I can return). The issue I’m now running into is that the chain is only maybe 3/8 to 1/2” away from the frame… the motor plates either hang out over the frame too much and are hitting the chain, or the minimum amount of adjustment for the motor is causing issues with it running into the chain… I don’t know enough about chain sprockets on these things to know that there may or may not be an obvious solution… Is it easy enough to move the chain and sprockets towards the driver side wheel? Or is that a difficult undertaking? The small block motor mount that Pancho originally suggested may work…my frame looks to be right at 6” in width and this bracket is 6.5” wide with what looks like the motor mounts off center in a way that would help https://www.gopowersports.com/fully-adjustable-motor-plate-small-block/
I did also find a new sprocket for the driven pulley that seems to be quite a bit thinner than the existing one… So I may today try taking the driven pulley off and replacing the rear sprocket and see how close it lines my pulleys up. Someone had asked for pics to see what’s on the passenger side of the motor, here they are
[side note] this has made me much more hopeful that the year the AI robot takes us all over is further down the road that we think…y’alls knowledge puts ChatGPT to shame
