40 Series Pulley Alignment Question
Hey everyone I got a new 40 Series Torque Converter from GoPowerSports. I just wanted to know if it is aligned the right way. Wasn’t given instructions for it and I’ve seen a lot of different takes online unsure of which is correct. Thank you?
Cant tell for sure but it looks a little crooked. Maybe remove a washer from the driver but again, I cant tell perfectly. Looks a little out of alignment to me.
Sorry denny your incorrect.
In that pic CCC, if direction of travel is up, then the orientation is correct. The rubber buttons must be on the trailing side of the wedge in the direction of rotation.
A 40 series is symmetrical, so it can be run either way, but you have to change springs to wind it the other way.
I made a quick video explaining it to some one else. Ill post it again.
Okay, thank you for the response, I have a video I took but I’m not sure if it’ll allow me to upload here
I made a quick video explaining it to some one else. I’ll post it again.
I saw your video, thank you again for the link. The power is traveling towards the top of the photo. I do have a video of it running at idle and full throttle, and the pulleys are adjusting the ratios as usual it seems. I was just looking if belt wear/belt breaking was likely with the setup I have now. If I am able to upload videos here I’d be happy to upload! Thank you.
Since the angle is the same on both sides of the pulleys, the alignment is not quite as critical as with a 30 series. If its working good, run it for a couple of hours and then check the belt for wear. In your picture, they look plenty close enough.
