Belt requirement not matching belt chart
qpgmr
Rock Hill, SC
So I received the stuff I ordered and went to work. After getting the riser on, I saw that the chain sprockets weren't lining up, so I loosed the bolts holding the large sprocket and took a mini sledge and knocked the large sprocket out to the end of the leftward space available that you can see in the pic. Those are aligned now, but have another issue. The riser mount does not allow the engine to slide back enough to prevent the gas tank from hitting the bar in front of it when the frame flexes. Here is the mount I'm using. Can anyone recommend a riser that will work for this combo? I've seen others that are square tubes but they only give 1" rise and I'm not convinced that's enough. It seems ridiculous that I might have to drill holes.
Atlanta, GA
Well that frame was not designed with that engine in mind, so drilling, cutting and/or grinding might be a part of the conversion. That's actually the fun part, making it work.
….After getting the riser on, I saw that the chain sprockets weren't lining up ….It seems ridiculous that I might have to drill holes.
Like what Ezcome said...
In this hobby nothing is “drop-in”, nothing lines up and if it does, it’s not *perfectly* lined up. Part of the disgust comes from cutting up pristine parts you just bought; it seems a travesty. I think what really helps is doing a good job when you mill, drill, bend and twist so it looks “factory” and not like such a shade-tree Bubba hack job. That eases the mind for me. I have a decent but not total case of perfectionism.
qpgmr
Rock Hill, SC
After putting the torque plate back on, the available space on both shafts seem insufficient. Here’s a pic of how far the driven retaining nut can go, and the crank only accommodates a small part of the hub driver. I know people are putting 224’s on with clutch plates. Is this really OK?
qpgmr
Rock Hill, SC
Here’s more pictures, realized just that one wasn’t very helpful. There is MAYBE 1/4” left on the crank. Is that really going to be ok? As for the driven, what should I do?
qpgmr
Rock Hill, SC
The backplate, cvt and both sprockets were already on it when I bought it. It had a #40 chain. It was driven quite a few times and no issues with the chain. I'm trying to keep using the backplate so I can put a cover on it.
Thats about how much room I have to put the other half of the driver onto. Pacman washer holds it real tight.
That looks exactly like the CVT kit I got from GPS so I assume its the same parts.
Did you have the driven assembled before and the nut went further on the shaft? It should stop flush.
qpgmr
Rock Hill, SC
This is a polite way to exclaim about what I found out this weekend. The belts I bought had their arrows toward engine printed backwards. Meaning, the arrows incorrectly point toward the TAPERED side. This is how my belt got stuck with the Tecumseh and how this all began.
WATCH OUT for this when purchasing belts!!!
It did with the 195cc Tecumseh. I understand on the driver, the larger 224cc Predator causes the plate to sit away from the engine by the amount you're seeing. I put blue loctite on it, should be OK(I hope). The driven I'm not understanding. The parts are all the same, shaft is fully to the left, and the driven pulley flanges are certainly not farther apart and tight with the belt. I put blue on that as well.
Now I have to replace the throttle cable, rod collar and maybe even the rod. Still looking for these, and I don't want a cable where I have to cut a barrel off so I don't risk trying to stick another frayed wire end into the hole on the stock predator throttle. Good luck to me. No project using my hands ever seems to be completed without much difficulty.
Driving too aggressive to be Andy Griffith, must be Rosco P. Coltrane. Promoting the local economy?
Could be Deputy Barney Fife, you know how emotional and erratic he was, or maybe Enos (DoH)?
EdwardWare
The chart is usually just a starting point; real-world setups can vary with clutch position, pulley alignment, and belt brand. If the belt has no slack at rest, it’s likely too short. I’d double-check the center distance measurement and alignment, then try the next size up.
qpgmr
Rock Hill, SC
Thanks EW, a little further up the thread I found out that I had the belt on backwards, relying on the arrows which were printed backwards. Now struggling with the throttle. I feel like a heel constantly telling the girls it's about to be fixed and then nothing.
