predator 212 engine wont start
GEEFYVEN9NE
worked before i did the work replacing crankshaft i adjusted the valvles to .003 cleaned the carburator idk what else i could do to get it to run
Did you align the dots on the cam with the crankshaft?
Did a lifter fall out? They have a tendency to do that.
What else?
Aftermarket carb or original.
Got spark?
Got fuel?
GEEFYVEN9NE
What else?
Got spark?
Got fuel?
yeah i alligned the dots on it, original carb and by lifters you mean the little things that hold the rods for the valves? those are in place got a good sparkplug and got fuel and oil probably just gonna get a new one if i cant figure it out lol
How about some info about what its doing?
All we know is, it worked, you worked on it, now it doesn't work.
Does it try to sputter?
Can you pull the cord and the engine turns over? Or does it lock up at some point?
Simple things.
Is the switch on?
Did you pinch a wire and its grounding the coil?
GEEFYVEN9NE
Does it have spark at the plug? Does it have gas in the carburetor bowl? Does it have compression?
Did you replace the head gasket and torque the head bolts?
got spark and the gas and compression i dont have any gaskets i can use besides the ones that came with and theyre fine, and if in thinking what you mean by the head bolts those are right too
GEEFYVEN9NE
Simple things.
Is the switch on?
i think it tries to sputter it makes noise when pulling it like i pull it makes no noise and wont lock up like completly and its on and the ground wire is in the same place it was originally
GEEFYVEN9NE
Spray some carb clean in the throat and pull it. Does it try to pop off then?
imma have to get some carb clean and try that but you reminded me that first time i tried starting it it make a pop noise so i might have messed something up already? or would it popping be fine
Well the timing has to be right.
Did you mess with the flywheel or coil?
You can squirt gas in the throat too.
Anything flammable.
If the engine has air and fuel mixed at the proper AFR, compression and a spark at the right time it should run.
Gotta find out what's amiss.
If it wants to pop off with some added gas down its throat its a sign the timing is good.
If it doesn't then it could be something to look into.
Sheard flywheel keys have tricked a many peeps.
GEEFYVEN9NE
Anything flammable.
i wanna say it could be the flywheel key because the “”new”” crankshaft was horribly taken care of so i dont doubt the keys messed up i would put my other crankshaft in but the bolt hole for the clutch is stripped and im too lazy to rethread it and nobody else would do it for me
imma have to get some carb clean...
Good to have for its primary purpose (cleaning carbs), but you can also dribble raw gasoline down the carb's throat and it will do the same thing. Take a 16 oz soda bottle fill it with gas and punch a nail hole through the cap. Which reminds me, I want a dedicated squirt bottle for gasoline to fill up float bowls...
Sparkwizard
Richlands ,NC USA
Pour some gas on a rag, hold it to the carb and pull it slowly a couple of times. Move the rag 10 feet away from the carb and pull it hard.
If it wont sputter like that, remove the flywheel and look at the key. How did you remove the flywheel the first time?
