Offroad big block buggy
Eztrail
Cleburne, Tx
Well, I made this mount for the rack and pinion but it was too short. Guess I didnt double check the tie rod angle after I tacked the bracket. Taller mount is in the background. Didn't feel like grinding the mounting plate off the shorter tube tonight. 20260423_193550.jpg
Eztrail
Cleburne, Tx
Nothing picture worthy today. Did some final assembly of the passenger side trailing arm and wheel hub. Keystock for the sprocket and cv shaft plate. Probably do the driver side tomorrow.
Eztrail
Cleburne, Tx
Ok so the longer front wheel studs didnt fit. I ordered new ones today. I hope Dennis Kirk will take them back and not charge me any stupid fees. 20260430_192715.jpg So corse correction, started working on motor plate jackshaft tensioners. This setup is just tacked while I was testing function. Seemed to work great so I burned it in. P.s. I gave you a nice close up photo to see the tensioner, not judge my not so perfect oblong axle slot!
Eztrail
Cleburne, Tx
Finished tensioner on both jackshafts, built a tensioner for the rear diff. Cut and installed tube on jackshafts on either side of the Sprockets. Bolted down the motor, installed the driver. Ect. Yada yada yada20260502_175649.jpg
Eztrail
Cleburne, Tx
Down to the less exciting part of the build, final details and assembly. Then finding what I need to rework. Will try to post up pics and details next time I'm out in the garage
Eztrail
Cleburne, Tx
Wanted some extra clearance for the chain on the rear diff. 20260508_183744.jpg
Final assembly of the front end is complete. Also lubed the grease fittings. Added another hiem joint on the steering and now its rock solid. And yes there are a couple nasty impurities in the back weld that came up. They need to be cleaned up. I ain't hiding anything lol
