Replacing Cast Rims on a Manco 405
JohnnyReb
What steel, inexpensive rims can I use to replace my original 5" broken rear cast aluminum rear rims and my original front cast 4" rims.
Your Manco 405 is a dead axle kart eh? Might need a sprocket hub....
EDIT: keep us apprised of the situation and post some pics of your kart. Always pays to have some eyes-on.
:useless:
JohnnyReb
JohnnyReb
:useless:
There's a 4" for $13.75 a piece in the below listing but those light duty dolly bearings must be pressed out and replaced with precision sealed bearings.
4" https://azusaparts.com/product-category/wheels/steel-wheels/4-steel-wheels/
5" https://azusaparts.com/product-category/wheels/steel-wheels/5-steel-wheels/
IF you wanted to stay aluminum, you could go with Azusa Tri-Stars but they can be pricey.
TY for your help, I will get pic tomorrow, to frustrated today.
You do not, of course, want to use any thing tire related (except maybe the inner tubes) sold by Harbor Freight. These "go kart wheels" are anything but, but you see them everywhere used as kart wheels. They are intended for manually operated or pushed carts and dollies. They aren't durable enough either in the rubber compound, rim material or bearing type to withstand a powered vehicle. They will self destruct in short order....
JohnnyReb
I had not thought about those. I have used them in the past on things and the bearings seemed fantastic. They upon first glance look exactly like the bearings on my carts. I may have to give that a try.
Go back and read Hellions post again.
Do not use those harbor freight tires rims or bearings.
They don't hold up to hand trucks.
If that wasn't a typo, they are okay for the things at the bottom of this image. Personally I would use the solid rubber or flat-free wheels, but for a CART to be sure. 😇
JohnnyReb
I read it carefully the first time, I just choose to try it, TY. I don't plan on hossing'it all the time, it is for a couple of city kids.
JohnnyReb
Fair enough, but you still think HF wheel bearings are "fantastic"?
I think the ones I have personally seen and used are good. I would not use them on a go cart that I was going to put through the ringer with a 200 pound adult acting a fool. Having said that I would say that they might have a reasonable life on a cart driven by a 10 year-old great-grand-daughter and her younger brother around the mowed property of mine. Also, in defense of Harbor Freight, I think their products have improved since they began business and their bad rap is more myth that fact now. I maybe 100% wrong and you 100% correct, I am just a hard head and a glutton for punishment?????
