Retainer Clip
qtband
St. Louis, MO
This is the retainer clip on the differential that's on my Streaker kart. It's a 3/4" external clip, but it's thicker since it holds in the axle. Anyone know where to get one of these?
The ones in the local stores have them, but they are thin. Mine are thick because they keep the axle from sliding out on turns. I fear the thin ones will break.
Well then try a specialty place like McMaster Carr and make sure you know the exact dimensions of yours (including thickness, ID and OD or whatever applies) when you do the product search. You may run into a problem where you have a metric part but think it is SAE or vice versa.
*I use a digital caliper for such things.
You could double them up. Install three if they fit.
True, it's not the space shuttle, it's a go kart and as long as it's a non critical item like brakes....
Keep us posted when/if you find a 1 to 1 replacement part and where found, QT.
Sparkwizard
Richlands ,NC USA
True, it's not the space shuttle, it's a go kart and as long as it's as non critical item like brake....
A quote from a fellow racer in the late 80s..." Brakes just slow you down. They get hot even if you don't use them. Friction wastes speed."
