Need help identifying kart
PugzNotDrugz
I am new to all this so I thought I'd ask the professionals 😬. I bought this kart hoping it would be easy, well I don't know much so it's not. Was told by other groups that it has a GY6 engine. A lot of electrical wires are cut off and seen that some rubber hoses are disconnected. Can anyone help me with it1000018354.jpg1000018401.jpg1000018440.jpg1000018473.jpg1000018439.jpg1000018438.jpg1000018437.jpg1000018436.jpg1000018435.jpg
Congratulations on your start to an electrical engineering degree.
You have what looks like a chineese buggy. They go by many names and made by several companies but they all share the same idea.
There are many wiring schematics available on the web. They will all not be the correct one to the one you have but they will be close. Colors might not match but the connections will be similar. Your gonna have to trace back where everything goes.
We can help. You already started off good with pics.
All the bigger hoses look to be breather hose or emission related. Those will be non critical to get up and running. We can address those later.
Some of the wiring may not be used or necessary. Some of your loose ends my be from safety switches that were un done for easier use of machine. They like to have an occupancy seat switch and a brake switch and a neutral switch wired in before you can start the engine.
Do you have a good battery? Then does it crank over? Fresh gas?
Im gonna bet big money that carb needs a full teardown and cleaning. Not hard just tedious.
Lets see if there's any signs of life out of it.
Technically not a kart or go kart. WTR is right, it is a Chinese buggy, ATV, side-by-side. I mean come on, what go kart has mirrors and turn signals? 🙃
I think what you have is likely a Dongfang 200cc DF200GKA (if not some other brand and model). Yours has some slight detail differences to the one on the link like the wheel spokes and the extra driver and passenger side bars/braces. No telling what year yours was made.
But seriously, if it was a real go kart like a Yerf-Dog or something, you wouldn't have all the complications with the wiring and wiring harness. You'd love the simplicity of a Yerf-Dog.
Nice photos, bro. :cheers2:
PugzNotDrugz
A cool one 😎 lol but yeah im new to the game so i wouldn't know. Debating on selling this one just to get me a fresh new one 😅 a running one at least
PugzNotDrugz
Gas tank was empty so i added some fuel. I tried jumping the battery but I got nothing with the key
Basic features may help others identify these buggies like wheelbase, length, etc.
CAZADOR Monster 200
Features:
Reliable 170cc Air-Cooled, 4-Stroke High Quality Honda Clone, GY6 Engine
Roomy Design, Wide and long enough for two adults to fit in
CVT Automatic Transmission Fully Automatic with Reverse
Electric Start, CDI provides much easier control and handling
Hydraulic Disc Brakes
Racing Style Dual 4-Point Safety Shoulder Harness Seat Belt
Rear subframe pivot with adjustable-preload dual coil-over-shocks.
Durable Off-Road Tires
Adjustable Seat
Muffler: Tuned Sport Exhaust
Tough and Rugged Construction Throughout
Safety Cage w/ Foam Padding Surrounds Vehicle
Quality Metal Flooring
Emergency Brake
63 inch wheelbase creates ample legroom to further enhance rider comfort.
Steel frame is lightweight and features outstanding durability with superior rigidity for superb handling.
The CVT automatic transmission with dual-range (Hi/Lo) drive and reverse is the most advanced in this class.
This true 2-passenger machine achieves driver and passenger comfort with a handhold and 4-point seat belts for both riders. The superior seating position, adjustable driver’s seat provide unmatched comfort that all riders will appreciate. Kymoto's rack and pinion steering technology further reduces fatigue and strain on the driver.
This Go Kart Model is equipped with Kymoto’s most powerful 170cc engine
Upgraded Japanese Style Carb ensures peak performance in nearly all conditions.
Convenient cab-mounted shift lever (Fwd/N/R) provides simple transmission operation.
Almost 8-inch ground clearance delivers maximum underbelly protection in all types of terrain.
Large diameter front and rear wheel disc brakes provide unsurpassed stopping power, and the cab -mounted parking brake is simple and convenient to use.
Specifications​
Engine type -- 4-stroke, Single-Cylinder, automatic
Displacement -- 169cc
Horse Power -- 6.0kw (7500r/min) 8.2HP
Valve Configuration -- OHV
Compression ratio -- 9.0:1
Fuel capacity -- 2.1 Gallon
Final Drive -- Chain-drive
Gear Selection -- Forward & Reverse Single Speed
Forward Lights -- Headlights-LED Trim
Rear Lights -- LED Brake lights
Starting system -- Electric start
Suspension Front -- Dual Shock Swing Arm
Suspension Rear -- Dual Shock Swing Arm
Brakes Front/Rear -- Dual Hydraulic/Single Axle Hydraulic
Wheelbase -- 48 in / 122 cm
Length -- 94 in / 239 cm
Height -- 64 in / 163cm
Front tire size -- 21 X 7-10
Rear tire size -- 21 X 10-10
Seat -- Adjustable
Ground clearance -- 7 in
CAZADOR Monster 200
Features:
Adjustable Seat
Emergency Brake
Specifications​
Engine type -- 4-stroke,Single-Cylinder, automatic
Displacement -- 169CC
Horse Power -- 6.0kw(7500r/min) 8.2HP
Seat -- Adjustable
I think you forgot the most important feature. " This vehicle conforms to current applicable EPA emission standards."
CAZADOR Monster 200
Features:
Adjustable Seat
Emergency Brake
Specifications​
Seat -- Adjustable
You forgot the most important feature. " This vehicle conforms to all current applicable EPA emission standards." Mr. Pugs I wish you well on your upcoming electrical journey. Life is too short.
Yes! Im not going to give up just yet 🤣. Going to try out this harness and just figure out the hoses later
Nice. The “USA DongFang Wiring Harness 150cc 200cc (Upgraded AC+ Version 4.1)“ sounds promising and it’s USA made. Do a review after you get it and compare it to what’s left on the buggy. We know they 🇨🇳 use the cheapest components possible and their wiring and couplers don’t do well exposed to sun, rain, UV and the change of seasons; Not nearly as well as the Japanese stuff.
