American Ethos (2025) Electrathon America Racer
I can officially announce:
The work area floor...DONE :cheers2:
All "butted up" nicely to the storage container :thumbsup:
I swept sand into all of the "gaps"
...but, it keeps "fallin' thru" them cracks
...so, "this part" is still a "work in progress" ;)
A view from another angle
Gave these ol' bricks a whole new "purpose" in life :2guns:
That looks like a shipping container in pic 1 and 2. I have heard rumors that there is a storage container with 36 Karts and/or electric vehicles in it.
How about a pic?
OMG how rumors "grow" :smiley_omg:
For the record, I've designed & built up to ~25 karts...so far
...but, I've sold a few over the years (ta help pay for materials for more projects)
(V8 Chevy starter motor kart, El Dingo, Excalibur & 'wittle 'wesistor, my mini-Jeep ta name a few)
&/also,
"Robbed" parts off a few too (so they...needs some helps) (Damien, Torsk & Lunar Rover)
Sadly have had to de-commission a few
...some for-safety purposes (!ARRIBA!)
...& some ta keep my wifey happy (YA GOT TOO MUCH...SH*T)
* Actually re-painted 'em & changed the names
...but, don't tell...her ;)
** The container (at my house) in the pics is only a 20" unit
...& it's ~1/2 full of tools & materials
...& in the other 1/2 is Desteny's kart, the Hell-raiser, mini-Aerial Atom & El Moto (my electric motorcycle)
Most of the others are in a 40' steel shipping container, at my storage lot
...with my old Isuzu NPR parts trucks (have ta get ya some pics...later) :cheers2:
I've been workin' on "plug" mold(s) for a hood (actually a couple of different ideas)
I'm callin' this one NASCAR
This one Muscle Car (added a couple of layers (1" & 1/2") of shaped foam, on top of the 2" base)
Yup, Ducky's still a helpin'
Tried the spray foam as a "glue" to "bond" the pieces of foam together
...& even weighted the pieces
...but, the spray foam "glue" still "swelled up" quite a bit :eek:
While the foam "glue" was curin' on the Muscle Car hood "plug"
...I did some "body work"(foam shaping) on the NASCAR "plug"
...& then, added some body filler
Work in progress
I got the "bright idea" to "seal 'em up" with some spray primer
...but, quickly found that spray paint "melts" this foam :ack2:
The more exposed foam (not covered in body filler) the "worse" the effect :huh::furious2::mad2:
The spray primer "messed" the Muscle Car hood up, pretty goodly (badly actually) :ack2:
So, I concentrated on the NASCAR "plug"
After several coats of body filler
...& lots more sanding :eek:
...I got the "body work" for the NASCAR hood "plug" about done :cheers2:
What ya'all think of that "aerodynamic" profile? :2guns:
Painted/sealed up :thumbsup:
Another view
Carbon fiber is the material of the future! Its not a good idea to build submersable vessels withit, however.
Shhh, don't say that out loud good sir. I have it on good authority that carbon fiber deep sea submersibles are superb
...mechanisms for earning people the coveted Darwin Award
I test fit, the hood "plug" on the chassis
...& /also, been workin' on settin' up, my "new" work area :thumbsup:
Ducky, doin' an inspection (it's her "day" job) :cheers2:
The next day I started noticing some "shrinkage" (I guess ya would call it) :unsure:
* Why is it not blue in these pics?
...must be the lighting
...'cause it's still blue :2guns:
Like this :huh:
Shrunk enough to "crack" the paint :ack2:
Wow! it's "soft" up under there :(
Um...really soft :eek:
Then, to make things MUCH worse
...a piece of pipe rolled off the work bench
...& BOOM! :mad2:
Well...SHYT! :surrender:
What kind of primer did you use? The solvents may still be affecting it? Was it laquer or enamel based? You may have to ruff up the plug and use a coat of duraglass or tiger hair on it.
OK Let's try this again :thumbsup:
This time I'ma gonna "creatively cap" each layer of foam with a thin piece of 1/8" MDF
...like these "guys" :2guns:
* Notice "this time" I'ma puttin' (hidin') the "seam" between the (2) pieces of foam (in the middle)
** In this pic, the "base" is on top of the foam, for markin' the perimeter
I "glued" the "base" to the bottom (3M spray adhesive/glue)
...& then, "glued" the second piece of MDF, on top of the foam (sandwich style) :p
* This way I could use both pieces as "guides" for markin', shapin', smoothin' & sandin'
** Notice I marked the foam at ~1" on the sides
...~2" on the angles
...& ~3" across the front
Marked the front "angles"
...then, "trimmed off" some of the excess material
More excess "trimming"
Then, started smmthin' & shapin'
Kinda like this
* Notice how the "upper & lower" layers of MDF "act" as a guide?
* Notice, I'ma tryin' to keep everything nice-n-even :sifone:
First, I "brought" both sides to ~1" from the upper "guide" board
...then, (right side) workin' on "bringing the edge to ~1/2" from the "guide" board
...& then, I'll do the left side "to match"
Lookin' pretty angled
...& smooth too :)
Second layer is couple of pieces of 1" foam
...with a "creatively shaped" piece of MDF on top :thumbsup:
* Again, notice the "seam" (or gap) will be "hidden" in the middle
Then, we will use another layer of MDF
...on top of another piece of 1' foam
For this "upper" piece of foam
...I marked the bottom ~1" wider than the top
...so, we can "make" a nice angle
Then, a top piece of MDF, will "cap" everything off :sifone:
* Notice the "shaping" instructions (arrows & notes)? :unsure:
Weighted (gravity clamp) for gluin' ;)
* In this pic, I'm gluing the middle layer of foam
...& the middle piece of MDF
...& the upper piece of foam "down" to the "hood" :thumbsup:
Another angle
An aerodynamic profile, is startin' ta "take shape" :banana:
The top piece kept "poppin' up" :ack2:
...&/so, it needed some curvin'
My "bright idea" was to do a little "curve/bendin" over my leg/knee
...& then, "SNAP" (deja vous) :furious2:
"WTF"...I did it again :mad2::mad2::mad2:
Here is a more "flexible" replacement
Yup, a piece of Formica (countertop material)
...just like I used on the fender/floorboard project (deja vous...again) :thumbsup:
Yup, that looks better :2guns:
I'ma likin' that aerodynamic profile :sifone:
After a bunch more shapin' :thumbsup:
Ducky says "time ta seal 'er up" :)
Maybe try some Acrylic (water based) paint
...as it shouldn't "eat" the foam, like the solvent in the spray paint, did :eek:
So, I started off by givin' 'er a base coat, of Yellow Acrylic paint
Another view
1 more :2guns:
After letting the yellow paint dry for a couple of hours
I then gave 'er a good-n-heavy coat of green Acrylic paint :cheers2:
* I switched colors (yellow to green) to help ensure 100% coverage
...as we are tryin' to build up a bit of "paint film" thickness ;)
While the paint wasa dryin' Ducky says, "think ya can "fix up" the Muscle car hood plug, that ya "messed up"?
Hmmm...IDK...maybe
So, I did a bit of sandin' (better/more productive than justa watchin' paint dry) :cheers2:
Just worked on (1) side (at first)
...for a side-by-side comparison
Yup, seems like I ...maybe able...to "clean this thing up"
I'ma learnin' as I go :2guns:
Like, I found that the door/window kinda spray foam doesn't "stiffen up" (it stays soft & rubbery) :huh:
Like this
Close up (of the soft/rubbery foam layer)
Because I used the spray foam, as an adhesive, to "glue" the layers together
This soft/rubbery foam layer, runs all of the way down...both sides :ack2:
...so, I figured it may be best ta "dig" some out
* Also, I learned that "glue seams" can be problematic
...as some "glues don't "sand away" with the foam :mad2:
Like this
Ducky says "what about...maybe...tryin' some house type plaster (like for walls)
...as it doesn't have any strong/harsh solvents (like automotive body filler)
...& it may be a bit "gentler" on the foam ;)
I'ma "down" for more learnin'
...so, let's give 'er a try :thumbsup:
Used some of this "household body filler" as "fillet material" ta "fill in" & round the inner curves/transitions, a bit ;)
This stuff hardens up pretty goodly
Um...Oops...probably shouldn't have used my wife's spoon & cereal bowl :eek:
Ya better NOT tell her...DENNY :mad:
Ah...ha...go ahead & tell her :p
When Ducky woke up, from her afternoon nap, she reminded me..."the stuff washes right out" :cheers2:
Um...Oh yea...OK...phew? :smiley_omg:
Ha...ha...like it didn't/never even happen :bannana:
