Double Sprocket on Reverse Gearbox Problem
Silentwitness33
Hey folks,
Hoping someone can offer some insight. I purchased this unfinished go kart and ran into an issue with the reverse gearbox. I'm new to this world so please forgive my terminology.
The external reverse gearbox has a double sprocket (16T) paired with a double sprocket on the axel. I've read that double sprocket reverse gearboxes aren't that uncommon when paired with the GY6 engine and a long output shaft. However, on my setup there is barely enough thread to keep the gearbox on. In fact, the first time I fired up the engine, the nut spun off almost immediately. The only think I can think of is removing the double sprocket and replacing it with a single sprocket to gain myself 3/4 of an inch or so. But I haven't found a supplier who offers a replacement for this gearbox. The second alternative is to buy a new reverse gearbox with a single sprocket but I'm hoping to avoid that.
I've attached some pictures to show my setup. It's a Hammerhead style go kart with a GY6 engine with long output shaft installed. I would appreciate some ideas.
Karttekk
Elizabeth, PA
Silentwitness33
Thanks for the response. I reached out to the Hammerhead Performance website you referred to. Less than helpful. They appear to have a part which looks like it might work but they are refusing to provide me with measurements citing the trouble they get into if they are inaccurate. Here's the link for reference anyway:
I was hoping they would provide me diameter of the inner flange to see if it will marry up against my reverse gearbox.
I've attached some pictures of the kart.
Karttekk
Elizabeth, PA
DHeapster
Good day.
I have ran into this issue as well. The reverse drive is totally messed up. I am trying to find a new replacement but they only seem to have a single sprocket. Where mine is a double sprocket. Where you able to find a replacement one
HoppyT
Good day.
I have the same issue, have the original planetary gearbox there with double sprocket but no selectee linkage or mechanism
This is an old dead thread.
Most likely there will be no answer from the original poster.
My advice is to start a new thread, and post pics of what you have.
From there we can help you get what you need.
Did I say post pics? Yes. That helps us see what your specific issue is.
