How do you secure sprockets to an axle such as this?
modelengineer
Lord of the noise
Sydney, Australia
make a keyway in the axle would be best
second best would be to put tractor pins through it
third would probably be to weld it on a bit, but not so much you can't take it off
gokarter
Ah...so a keyway. Thanks.
So basically, I can assume that any go kart axle I buy has this keyway of 1/4" unless it says otherwise?
Okay. I'm still determining to go with live or fixed (I've never built one before) and I'm actually making it out of wood.
What parts would I have to buy in order to have a fixed v-belt single rear wheel drive? If you could post the parts in links, that'd be spectacular. :)
frederic
The Junk Man
New Jersey
I wouldn't assume that. The Northern Tool description specifically says it has a keyway. I would assume it has nothing unless it says so :)
gokarter
Kool. Now I'm wondering a bit about what the dimensions for a tire are.
For example, if a tire says 4.10/3.50-5
what does this mean? Would it be bad if, say, I used a 4.10/3.50-4 on the other side of the kart?
drscope
Did you READ the description?
"Full length 1/4in. keyways with stubs at axle ends."
IHcubguy
just a member
Coal City, Illinois
I got the same axle! The 1/4" keyway is full length, I got a one piece sprocket 60t #41 that has no hub it just slides right on, w/ two set screws and a 1/4" keyway!
IHcubguy
just a member
Coal City, Illinois
it's the rim size that makes it shorter , smaller rim= smaller overall O.D. of tire, In this case, with the tire size being 4.10x3.50, what changes width is 4.10x(3.5) this in inches
