I have a live axle and frame but i dont know how to assembale the axle because theres wheel adapters welded on the end
damianz23
I have a live axle and frame but i dont know how to assemble the axle because theres wheel adapters welded on the end
I wouldent be able to put a sproket on it?
If you can find a split sprocket, it will have to match up to the holes already drilled in the center flange (the disc thingy). Or you will drill new holes to fit it. The holes will have to be spaced perfectly around the center line of the axle, or you will have a bad wobble and it won't work right.
