Go kart not accelerating
Kaleb gardae
Hello, I bought a nun running go cart it has a gy6 carb and 150cc motor. I replaced the carburetor and it turns on now but whenever I give it gas it does not accelerate or move on reverse or forward. What could I do to fix it?
Karttekk
Elizabeth, PA
Are you able to rev up the engine at the carb instead of using the gas pedal? You might not have the accelerator cable tight enough or installed properly. Jack up the rear of the kart and put stands under it so the wheels are off the ground and see if it will rev up. Could have a stuck brake caliper or like Denny said, something in the drivetrain isn't right. The fuel is pulled into the carb with vacuum. Check if the vacuum hoses are installed correctly or not cracked going to the fuel valve under the tank.
Everyone throws a new carburetor at it because they're so cheap, but they're easy to clean or repair from bad gas in them (up to a point that is). Take the old one and clean it up and you'll have a spare and learn carburetors.
Kaleb gardae
When I rev it I use the car and the gas pedal both don’t work. And if I’m completely honest I’m not sure witch one is the vacuum line
Kaleb gardae
I cleaned the old one really good but it didn’t work. With the new one it worked
Karttekk
Elizabeth, PA
The vacuum hose from the intake manifold goes to a Y or T fitting. One hose on the Y goes to the fuel valve and the other goes to the carb. If it's a T, a hose goes from it to the carb. Been a while but I think this is how they go.
