Relocating Ignition switch control box
GoKartNarc
Maintained Machine
Lake Worth, Florida
I have a 420cc Predator engine for my go kart. I want to relocate the Ignition switch box closer to the steering wheel and use it as the kill switch. I know I have to cut the wires to get it there. My question is: What's the size of the wire gauge for the switch box to match up and make it longer? I am also going to disconnect the oil sensor. Can't seem to find the wiring diagram for it.
OPmini
moo
Phoenix, Arizona, United States
14 gauge or lower should work fine you can also use a solder sleeve to electrically connect the wire and insulate it. for the oil sensor there is a yellow wire coming out of the engine and it goes to a silver box that has a black wire coming out of it disconnect the black wire and voila! your oil sensor has been disabled!
Hollow45
Interested to see how you do this. I have a 420 as well and plan on do the same thing. I want a key start in the seat/steering wheel area. So far I have installed a kill switch and hooked up the wire to the black connector that the oil sensor was plugged into.
here's the wiring diagram for the 420s
unfortunately as with many chinese stuff, wire colours are not always reliable,
so do a continuity check with your multimeter to verify..
switch digram is in the drawing.
Sergio30519
Georgia
Sorry to bother how did you wire the kill switch to the 420
Hope one of these guys answers. It's only been 4 years 6 months 27 days. Even our moderator itsid is M.I.A. 🪦
TNThomas
Washington
Whelp, I am wiring in a kill switch pretty soon here, I'll post pics. Thanks to the OP, I am scouting starter relocation for my 670.
