3 Pin Plugs
FireJer
does anyone out there know where i can get any of these flat 3 pin plugs that go into the back of the switches besides buying an entire harness and hacking it up
thank you
FireJer
I saw those to but those are not the correct ones either I will try and get a better picture tonight when I get home these are female terminals inside the housing and the plug has those locking tabs on the outside they are odd ones thats for sure
Sounds like you need to start hacking, or get rid of the plug on the dash board side. Actually sorry to hear that you bought one of those Chinese electrical monstrosities. Go karts are supposed to be simple. Not so many bells and whistles. Sorry I'm of no help.
FireJer
Wagos and delete the plugs.. But I’m a big hack.. So it’s ok for me to do it without shame.
I have no issues hacking and rewiring I am actually pretty good at doing that , I just would like to keep the original switches in the dash if possible so was hoping to just find the plugs thinking it would be the easiest , never thought that finding a simple plug would be so hard , just thought I may have not been looking in the right places, but I have done alot of searching and still no luck , was hoping someone else out there had better luck then me finding, or just knowing where to go to get one, I could not imagine that a Chinese go cart would make their own plugs for their harnesses ,
Thepartsguy
You can keep the original everything with a banked wago.... Cut off the three wire plug splice and pop the wires into a 3 bank wago.
The plug just becomes a wago..
FireJer
oh gotcha i know what you mean now , and yes that would work fine but the plugs I have been looking for are the ones that goint to back of the switches ,, anything other then that i just use heat shrink butt splices or connectors , I have never used wagos but they look convent to use , but i am still lacking the understanding of what plugs go where to make them work , i have some time tonight when i get home from work to sit down with pen and paper and trace out all the wires to find find what goes where and what does what so I know where to plug the stuff into even . thanks for your help any and all input is apricated
On the df125 I had there were lights in the grill, and a light bar. The switch had a pair for each.
The guy just brought it back for me to fix the muffler that fell off. Stripped the head out when it did.
I might be able to help you if the harnesses are similar.
Karttekk
Elizabeth, PA
Talk to these people.
